Question about Panasonic KX-TG6021M Cordless Phone
Panasonic KX-A115CE bad keyboard response
I've had poor response from the keyboard on this handset for a long time - mostly contact bounce. I have to rpess the key very hard before it respondes, and often it then enters the number twice. Hence frequent mis-dialling.
I think it's dirty contacts under the keys: skin oils get down underneath. I have contact cleaner, but am not sure how to get the case apart. I have tried removing the two small Phillips screws at the battery end, but there are hidden fixings some where, and I don't want to break it.
Any ideas please, anybody?
Philip Tory
www.authorgraphic.co.uk
  • Philip Tory Dec 22, 2008
    Nice try, but it does not tell me how to open the phone casing without breaking off plastic lugs / clips inside.
    HELP!
U need to open phone and clean board with soem alcohol or soem strog parfum. Its work for me.
Posted on Dec 18, 2008
  • veselko Dec 23, 2008
    ohhh its dificult for me to explane how, cuz i got low english. But i can tell u that 1st u need to take battery out. im gonna ask my brother and im gonna told u for sure. Sorry for my bad english
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
I have a panasonic kx tga652 phone it says base no power on several of my hand sets
That sounds like a handset model, from any of a range of DECT Plus systems?
Panasonic phone support is horrible, but they're pretty good about keeping manuals available on their Panasonic.com (may need to select USA) support site. Search the model number not of the handset, but the system found on the bottom of the main base unit.
There are enough versions and configurations that it's hard to guess specifics, but those series generally have the ability to power the base from a handset during power failures. There could be a need to reset something, or bad batteries or connectors in the handset in the base. Try swapping which handset is left in the base, and inspect the batteries in all handsets (sometimes removing them shows corrosion, or cleans a bad contact just from handling). Most of those use regular AAA NiMH batteries, and so they're pretty easy and cheap to replace if needed.
Jan 23, 2015 | Panasonic Lands Phones
KX-TD7696 handsets failing to charge
Most times the connectors are just enough away from contact point. See if you are able to place a flat thin screwdriver to bring the tabs Foward a bit do not over pry as to not break prong. This should work also scrape connectors with same screw driver to bring original copper back
Nov 06, 2013 | Panasonic KX-TD7696 Ruggedized Multi-Cell...
How do i stop the panasonic KX-TGA641 from rolling calls to my cell phone
You apparently have call-forwarding activated. The exact procedure for deactivating it may vary by company, but in most cases you simply dial *73 on your phone (the Panasonic, not your cell). Contact your telephone company (the landline) for exact instructions.
Apr 24, 2012 | Panasonic KX-TGA641T DECT 6.0 ADDITIONAL...
The reciever on long distance calls complain of echo on their side I have a KX-TG4023
Echoes are created when you have a delay and has nothing to do with your local handset cordless or wired. It is the carrier that you are using that may be responsible for this problem. You need to contact your long distance carrier for this problem.
Mar 25, 2012 | Panasonic KX TG4023 Cordless Phone
I have a Panasonic KX-TG5633. It has worked fine for several years. suddenly one of the handsets no longer syncs to the base. I've followed the instructions to register it to the base, but it refuses to...
I am so tired of all the answers that don't help by repeating standard answers that you already know won't work or giving directions for a totally different product. The fix here is simple but not easy. It's either a bad charging/battery connection, a bad battery or both. Low power will cause the exact problem asked here.
As the phones get older, and I'm specifically talking about Panasonic cordless KX-TG563x but this may be true of other rechargeable devices, the metal contacts for charging and battery do not make a good connection like they used to. They may look perfectly fine and free of corrosion but are not actually making a good connection.
Symptoms include the phone getting hot while charging and not holding a good charge. The phone may show 3 bars of charge but still blank out like the battery is dying. With these Panasonic phones, weak battery will cause the phone to unregister and will give false charge level readings in the display. If your phone gets hot when charging, this is most likely your problem.
I had this problem with several handsets and used contact cleaner on the charge base, the phone contacts, the battery contacts inside the phone and on the battery itself. It fixed all the registration, heating and charging problems. I had one stubborn handset I had to clean multiple times but it's now working like new as well. I used DeoxIt contact cleaner from Caig, bought it on eBay. Great stuff. If repeated cleaning of the contacts with a good contact cleaner does not fix the phone, replace your battery. Use contact cleaner on your new battery for best connection. Ebay is a good source for replacement batteries as
well. Good luck!
Feb 11, 2011 | Panasonic KX-TG5633B Trio Cordless Phone
Panasonic KX-A115CE changing pulse to tone dialing
Can anyone tell me how to change it? There is an option ''Setting Base'' on the handset and when I enter it it says ''Input Command'' but I have no idea what should be entered.
Thanks a lot!
Oct 14, 2009 | Panasonic Lands Phones
Suddenly have voice mail messages on handset (beeping before dial tone) when hooked to external voice message machine. I am using Vonage as my company.Panasonic hands free hooked to 4 handsets. Model is...
vonage gives you a personal voicemail. You should contact them and find out how to retrieve it first. If you have your companys voicemail on the panasonic you should also make sure that vonage voicemail get longer waiting time.
Jun 15, 2009 | Panasonic KX-TG5621 Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX-TG6021M Cordless Phone Logo
841 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
