Question about Amana DRB1901C Bottom Freezer Refrigerator
Compressor not starting
I have a Amana refrig. bottom freezer model DRB1901C. It is located in the garage western NY.(current temperature low -mid 30's) I noticed yesterday the freezer was open slightly. Opened door and saw ice crystals, it seems evident compressor running for extended period of time. I shut it off and came back later, does not start up. I then place a haligon light at compressor and at entrance to freezer to warm up. Tested thermistat and it is ok. I'm looking for some advise on what to check out next. Does the compressor have a resettable overload? the refrig is approx. 3 years old (I think) I bought it last summer and it's in new condition, until yesterday...
Thankyou for any advice...Tom
  • thomasvay Dec 01, 2008
    Thankyou for the response. I tested the thermostat in the freezer. It has the on/off control for appliance. The refrig section was most likely at around ambient temp.(32F) but shouldn't the freezer section continue to operate the compressor to maintain 0-2 degree F in freezer?
    President:
  • 1,462 Answers
The thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
Posted on Dec 01, 2008
My DRB1901C is not freezing. It's sounds like its trying to kick over for a few seconds then fails.
If neither cooler or freezer is working it sounds like the compressor is locked up. When that happens it tries to start and will hold the start capacitor in until it overheats the safety contacts. It will overheat in about 3 seconds and then kick out. This happens sometimes if the door is opened right after the compressor has turned off because it is cold enough in the cooler/freezer. However if this continues time after time and the compressor does not start, you probably need a new compressor. You may consider a new refrigerator, since compressor changeouts are fairly expensive.
Sep 21, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
Runs constantly, doesn't cool
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 20, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Where is the defrost timer
Should be down in front behind the kick panel.... If not then it will be in the compressor compartment.
Aug 05, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Refrig and freezer not getting cold
HI, Can you hear the compressor running? Does it click like something is trying to start but can't? It sounds like the compressor is not running. The compressor should have a 5 year warranty. They are having problems with these compressors so, you might want to call Amana and see if it is under warranty. I hope this gives you some help. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Amana ABB2227DE Bottom Freezer...
I have an Amana bottom freezer, model BX20S5E that is not cooling properly in either compartment. I have replaced both the defrost thermostat and defrost timer (new). Still no change... what I do notice is...
check door gaskets and see if problem is moisture,or air gate to fridge compartment not working properly.I would recomend verifying defrost cycle is working by turing defrost timer to defrost cycle,it will click when engaged when unit is frozen and heater should come on if all is well,if not heater is probably culpret if the rest is new.
Apr 09, 2009 | Amana ARB8057CSL Bottom Freezer...
Where is the water filter in the bottom freezer amana energy saver model refrigerator; and how do you change it?
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
Feb 17, 2009 | Amana ABB1927DE Bottom Freezer...
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Mar 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Amana DRB1901C Bottom Freezer Refrigerator Logo
194 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
