Question about Goodman Heating & Cooling
Heater not staying lit - Goodman Heating & Cooling
  • 2 more comments
  • rdallen Dec 01, 2008
    Goodman Model # GMH950703BXAA Ser. # 0612626994 Gas type = LP Two years old.
    Unit operated flawlessly for two seasons. This season it started acting up as follows:
    Thermostat calls for heat----Exhaust fan starts running-----Ignitor comes on----Burners light-----Blower fan comes on-----After about one minute the flames go out-----both fans continue to run------Ignitor activates------Burners light and burn for another minute to ninety seconds, then go out again. This cycle continues until thermostat reaches set temp. Status (red) LED stays solid on indicating normal operation. I replaced the thermostat and the unit ran normal for several days before starting the intermittant lighting again. I have a multimeter and can replace parts in this type appliance.
    12/01 Flame sensor was removed and cleaned with fine emory cloth. No change. Where do i check the flame sense signal?
  • rdallen Dec 04, 2008
    This info was helpful in finding where to start. The furnace now extinguishes and re-ignites several times while bringing the room temp. up to thermostat request. I'll install a replacement flame sensor this weekend and proceed from there. Something is telling the gas valve to close and i need to find out what it is.
  • Joseph Lillie
    Joseph Lillie May 11, 2010
    Hello and welcome to FixYa.
    Can I have the full model number, serial number, type of gas?
    What exactly is the unit doing?
    Do you have skills to work on this type of appliance?
    Do you have a electrical meter?
  • 61 Answers
This from the installation manual on your furnace.
I think you need check the flame senor for proper output. if the output is correct you wil have to switch the electronic board.
FLAME SENSOR (QUALIFIED SERVICER ONLY)
Under some conditions, the fuel or air supply can create a nearly
invisible coating on the flame sensor. This coating acts as an
insulator causing a drop in the flame sense signal. If the flame
sense signal drops too low the furnace will not sense flame and
will lock out. The flame sensor should be carefully cleaned by a
qualified servicer using emery cloth or steel wool. Following cleaning,
the flame sense signal should be 1 to 6 microamps at 115
volts.
Post me back and let me know.
Posted on Dec 01, 2008
  • Joseph Lillie
    Joseph Lillie Dec 01, 2008
    You disconnect wire and test through your meter. Your meter will need to read microamps.
  • Joseph Lillie
    Joseph Lillie Dec 04, 2008
    most likely the the board that sensor goes to
Glo-Warm gas wall heater. Why don't pilot and flame stay lit?
check the thermocouple. easy to replace. inexpensive
Jan 19, 2016 | Heating & Cooling
My reddy 30 heater will not stay lit after starting I have held the switch down for longer than 30 sec but it just want stay lit
thats sounds like a thermocouple problem its located right by the pilote light assembly,,,rod shaped object
May 14, 2010 | Heating & Cooling
Pilot will not stay lit and heater will not light
thermocouple probablly bad, is the flame covering the thermocouple.
the flame has to hit top portion of thermocouple to work correctlly.
Feb 14, 2010 | Endless Summer (GA200209) Stainless Steel...
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
try taking a air hose and blowing all the dust out
Oct 13, 2009 | Pool & Spa
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Heating & Cooling Logo
318 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
