Question about Toshiba Satellite P205-S8811 Notebook
Downgrade from Vista TO Xp
Can i downgrade from wista 32 bit to winxp on a p205 s8811 laptop
  • 1 more comment
  • Anonymous Dec 01, 2008
    I just bought the new laptop toshiba satellite p250-s8811 with windows vista home Premiun pre-installed and I want to downgrade it to windowas vista
  • insanecobra8 Mar 05, 2009
    I can use some help.. I have a Toshiba P205-S8811. I downgraded from Vista Home to XP Pro... I can not find three drivers. Video , Wireless , and LAN. hAS ANYONE come accross comaptible drivers for these devices.
  • Asdf hsdf May 11, 2010
    Please tell me your laptop os is upgraded xp to vista. or it has already installed windows vista.
  • 1,498 Answers
Hi Bienana,
Steps must be taken in advance. Laptops are different from desktops. They have proprietary drivers that need to be available for boot or bad things happen. For example the CD-ROM won't be there any more. Then how will you load anything?
What you will have is a plastic rectangle that keeps asking for an operating system you can't install.
First, create a boot disk.
Second, create another boot disk.
Test them both. Make sure the CD works.
Now for some alternatives to formatting your hard drive.
Click here for a site thats offering Windows XP recovery CD's to those Vista owners that want XP. The offer is good through July 31, 2009.
Click here For the Toshiba site specifically for downgrading Vista to XP. It's a source for the drivers that inevitably don't get copied, what rights you have for which version and so on.
Both sites will give you some important insight before you take the plunge.
Mike
Posted on Dec 06, 2008
  • Justin Case
    Justin Case Dec 09, 2008
    Dear Bienana,
    Some additional info and a few questions for you.
    1. Have you ever performed a clean install on a notebook or laptop?
    2. Do you know what a clean install is?
    3. Have you ever formatted a hard drive on a laptop?
    4. Why is it necessary to preserve proprietary software?
    5. Can you program in more than a dozen languages?
    6. Can you configure 50+ machines and get them networked for a national expo in under 48 hours?
    Back on topic:
    Have you attempted your downgrade yet?
    - If yes, How did it go?
    - If not, don't you think it a bit premature to dismiss a solution you haven't tried yet as irrelevant?
    I could have answered your question with a single word: YES.
    I could have mirrored the same energy you put into the question: YES, If done with the proper advanced preparation.
    But the 30+ years of programming experience I have told me that you could use more than a single syllable or a one liner.
    The truth is you can downgrade just about ANYTHING. Just installing any prior version will do it. On a Laptop though, if you make one wrong move or omit one step, you can end up with an expensive piece of plastic that has one trick. It will ask you to insert an operating system disk. And you won't be able to.
    I assumed you left unsaid that you would prefer a working machine and your data still accessible upon completion of your hypothetical downgrade.
    I also assumed you were unaware of the possibility of reducing your machine to a doorstop/wheel chock. The absence of any feedback on your part (except of course your generous rating) necessitated these assumptions.
    So I spent the time to find you two sources that are essential for you to meet that goal.
    • A recovery disk is a reverse upgrade. A DownGrade.
    • The exact Toshiba page to download proprietary drivers
    Maybe you remain unaware of the potential consequences of starting a procedure like this without planning it out.
    - Just about everyone answered your question as it was asked.
    Maybe you misunderstand the rating system?
    - FixYa means the solution fixed the problem. Too early to tell?
    - Helpful the minimal for constructive well thought out submissions, solved or not..
    - Thanks For Trying means that although an effort was made, that solution did not help fix the problem. (Premature at best)
    - Inappropriate means that the solution was either so far off base as to be laughable or it was profanely abusive. (Not the case)
    With nearly 200 Toshiba laptops (Satellite, Tecra, etc.) under my belt, do you think that somewhere along the line I might have picked up a thing or two?
    Having hindsight as to what can go wrong and the turmoil it can bring you compels the undeserved generosity being demonstrated here.
    So the choice is yours. I pay forward some of that knowledge knowing that if you use it correctly, you might come out of this with a functioning machine.
    If you ignore my posts and decide to format your hard drive for a clean XP install, chances are the profane abuse will be coming from you after the first automatic reboot.
    Good luck
  • Toshiba Master
  • 4,806 Answers
Yes you can downgrade to XP, check the driver download page here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1932631&rpn=
PSPB3U&modelFilter=P205-S8811&selCategory=3&selFamily=1073768663&selModel=1932631%7CPSPB3U
regards and please don't forget to rate us
Posted on Dec 01, 2008
    President:
  • 216 Answers
The first thing to do is download all the XP DRIVERS You'LL need for the install before loading windows xp so when you install xp you have drivers for the network card :() i run a local shop i see it every week people reinstall windows to find the do have the drivers and cant access the internet to download .. the drivers they need after installing xp on some computers
Posted on Dec 31, 2009
  • 849 Answers
No, u ave to format your system for such downgrading.
  • Toshiba Master
  • 6,487 Answers
Yes you can downgrade from Vista to XP, you just need a XP installation CD and reformat the computer to load XP on it and that should be it....
Toshiba Satellite P205-S8811 all of a sudden it shuts down when i try to play games.
Sounds like it's overheating.It's a common problem with alot of Toshiba's.
Nov 25, 2011 | Toshiba Satellite P205-S8811 Notebook
Satellite P205-S8811 microphone sounds very faint and no one can hear me when i make calls on skype or try to record something
Bottom right corner and right click on the speaker icon in the taskbar, left click recording devices and you will see microphone, right click, properties, levels, adjust them as you see fit.
Mar 06, 2011 | Toshiba Satellite P205-S8811 Notebook
How do you do a full system restore on toshiba satellite p205-s8811 without a restore/recovery disc.
Press "1" or click "Restore Original FactoryImage." Click "Yes." Select "Next" to begin therestoration process.
Feb 11, 2011 | Toshiba Satellite P205-S8811 Notebook
I NEED TO CHANGE FROM 64 BIT VISTA OS TO 32 BIT " XP OR VISTA OS
Ummmm. Its quite expensive to do that but i suppose if you need to ten its a viable option. You could buy a cheap 32 bit machine instead or try downgrading vista.http://www.microsoft.com/windowsvista/1033/ordermedia/default.mspx This may help you if you retail bought the machine.
Jun 24, 2009 | HP Pavilion dv5-1150us NoteBook
Downgrade 64 bit to 32 bit
Are you downgrading from 64bit Vista to 32bit Vista?
If so you will need to purchase the complete installation for 32bit Vista. You insert the disc into the computer, when it asks "press any key to boot CD" press any key, it will start the windows installation. Just continue through with everything. Be warned that this WILL erase all data off of the computer.
If you are trying to downgrade from Vista to XP you will need to find out if the manufacturer ever released drivers for XP for that model of computer. Most newer machines are not XP compatible anymore.
Apr 13, 2009 | Computers & Internet
Drivers for P205-S8811
Go to the Toshiba Website Here and download the drivers for your laptop. You will need the model number as shown on the base on the main sticker, and also the short code may be useful.
Cheers :)
Mar 05, 2009 | Toshiba Satellite P205-S8811 Notebook
Software incompatibility on my acer aspire6930-6455
Well, we wont know until you try. In my opinion, your 32/64 bit issues will be solved, but you would still have the normal vista/xp compatibility issues.
But that is to be expected, like when we all upgraded from win98 to XP.
So - I would recommend downgrading to Vista 32 bit, or getting the 64bit software version of the programs you want to use.
Good Luck, and let me know what you did, and how it turned out! :)
Jan 07, 2009 | Acer Aspire AS6930-6455 16" Notebook PC
I downgraded my Toshiba P205 laptop from Vista to XP PRO
Since you do not have the original restore CD more than likely you're missing the hardware drivers specific to the Satellite P205.
Have you tried:
http://www.driveragent.com/?gclid=CM2d2ora55cCFQ0xawod_m-0Dg&PHPSESSID=mim
Dec 30, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P205-S8811 Notebook Logo
352 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
