External usb hard drive does not work with startech usb card s/n PC1265USB21
  • brandonson May 11, 2010
    is this a pci card or are cables connected directly to *********** boards usb ports
  • 849 Answers
Try the hard disk on the builtin usb port or to the other computer for confirmation.
Posted on Dec 01, 2008
Need connector
I found this possibility
http://www.startech.com/HDD/Enclosures/18in-USB-to-Micro-SATA-Hard-Drive-Enclosure~SAT1810U2 - I am sure you can buy this in other countries, perhaps through Amazon or other retailers. I am sure there other manufacturers of similar products besides Startech.
22.April.2014
Apr 15, 2014 | Samsung SpinPoint 3600RPM 1.8" 5.0mm...
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
My external hard drive os gives a clicking sound
Improve the FixYa experience for everyone by voting.
It sounds as though you have software incompatibility problem. With a bit of good fortune, Microsoft can diagnose the problem( s) and fix it in three easy clicks and it's free. CLICK HERE
If that doesn't do the job, you'll have to format the hard drive. Hopefully, you've been backing up everything on the external drive because the formatting process erases everything.
May 21, 2012 | StarTech.com InfoSafe Mobile 2.5" USB 2.0...
External hard drive not showing in
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 31, 2012 | StarTech.com InfoSafe Mobile 2.5" USB 2.0...
Download drivers IDE/SATA enclosure USB2.0 external hard drive enclosure
Hi Walter, what happens when you just plug it in? my drive enclosure does not need drivers as it is a storage device.
Nov 22, 2010 | StarTech.com Infosafe 2.5" USB 2.0 Extra...
Samsung external hard drive not recognized
its happens when the hard drives cable or usb port is problem
change the ccable then try
other wise plug the pci usb card & first diseble the motherboards usb port
then try
ok bye..........................................
Nov 17, 2009 | Computers & Internet
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
David Payne
David Payne
