Question about HP Office Equipment & Supplies
I have installed an new red cartridge but it prints out with tones of orange mixed with not so good reds
    Problem Solver:
  • 11 Answers
Calibrate your printer and do head cleaning test
Posted on Dec 01, 2008
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
Printing yellow instead of red or orange
Hi Friend,
Firstly clean the head of cartridge & printer.if you have cleaned the head, that's the best way to get the color out.... did you also clean the head on the cartridge holder where you insert the cartridges?
If you useing Refill kits (cartrige) please replace it with a NEW one printer cartridge becouse refill cartridge is not every time good.
Thanks,
Jan 15, 2010 | Epson Stylus CX6600 All-In-One InkJet...
No red
the color red is a mix of two color. so run the cleaning tool on the printer
Dec 12, 2009 | HP PSC 2175 All-In-One InkJet Printer
The upper 2/3 of the word is either red or yellow
let the cartridge be new but the colours are got mixed with each other so this problem as the canon cartridge has the sponge in the cartridges that sponge material has soaked the colours from each other and this has happened.to solve this problem two things needs to be done 1)the head needs cleaning as the colour will be filled in it now.
2)the cartridges needs to be replaced.
Dec 15, 2008 | Canon BubbleJet i560 InkJet Printer
I have a hp desk jet model 710c printer. I have cleaned and aligned the printer. The color red does not print. A test print will not print RED. Do you have any suggestions on what to try?
simple.the ink in the colour cartridge is over.usually pink and yellow mix to form red any of the 1 colour is over.just get your cartridge refilled or buy a new cartridge.the printer is absolutely perfect.
thanks.
Nov 14, 2008 | HP Office Equipment & Supplies
New cartridge but copier not printing
Did you pull out the orange/red tape?
Check if there is an good connection between cartridge and pin at the right side of crg. inside crg.holder( a little pin wich goes in and out when you open or close cover )
Try with old crg. if it works the problem is new crg.
Sep 06, 2008 | Canon imageCLASS MF4690 Multifunction...
Cartridge
did you do a clean cartridge and re alignment first?
http://tinyurl.com/6qcpgy
Aug 08, 2008 | HP PSC 1410 All-In-One InkJet Printer
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
