Question about Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop
Used Dell Dimension 3000 drive issues
I have a used Dell Dimension 3000 without windows, as I'm installing a 250 gig WD hard drive. I connect the drive, and checked bios. hard disk, and cdrom drives both show in bios, however nither disk will spin, i.e. disk won't turn. Hard disk is getting power. And sometimes when I boot up it goes to the Dell logo, and hangs. Can't figure this one out. Can someone give me an idea of what to do. Thanks....
  • Rick Formosa Jan 26, 2007
    I failed to tell you that I have not been able to load Windows XP. im working strictly with dos at this point. but i will try that. thanks, Rick....
Have been trying to exit bios screen setup press differet commands nothing works can you slove this problem.
Posted on Jun 13, 2009
    President:
  • 2,961 Answers
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Posted on Jan 26, 2007
  • andrew pester
    andrew pester Jan 26, 2007
    Win xp only uses a basic dos system unlike win98, so you can format with a win98 floppy boot disc with cd rom support, then insert the xp disc when prompted, but it's easier the way i suggested first.
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Booting problem
I'm thinking the boot sector or master boot record was not written to the new disk or is corrupted.
Try running the recovery console from the installation CD and take a look at FIXBOOT and FIXMBR
Nov 07, 2007 | Maxtor (6L250R0) 250 GB Hard Drive
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
Having Trouble Reinstalling XP on my Dell Dimension 3000
Here's what I would do. Download and burn any Linux disk. Install Linux and delete all partitions while doing so. After that, initiate the Windows XP installation and see if that works.
This will take care of two things:
If you can install Linux, then the hard drive is good and the partition that was previously on there will be deleted (I suspect the partition is locked which can be caused by a virus or the software used to scrub hard drive).
Check your CDs for Windows (for scratches) or it could be your actual CD drive is out (laser) which would make the installation fail. If the CDrom cannot read the disk, it locks up like that during installation...even if it read before.
Sep 22, 2009 | Dell Dimension 3000 PC Desktop
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
WD portable 250 gb drive w/20 gigs of pictures
Is it truly broken or just not working, ie, not being recognized?
If it is broken, there are companies who specialize in data recovery.
One site is:
http://www.harddiskrecovery.net/
I've never used such a service, but they will give you a free quote.
Oct 14, 2008 | Western Digital 250GB MyBook External USB...
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Hard drive
Could you be more specific? Do you mean you had 28 gigs on your hard drive used up, but the backup only copied 7.5 gigs? The message you left is pretty sparse.
Apr 15, 2008 | Dell Dimension 3000 PC Desktop
Boot problem
you have to set the master boot record to bootable.. I dont know how you would do this in windows, maybe you can do it with grub or something.. or maybe just search google for restoring master boot record(mbr).
http://www.google.ca/search?q=restore+xp+mbr&ie=utf-8&oe=utf-8&aq=t&rls=com.ubuntu:en-US:official&client=firefox-a
Dell Dimension 3000® Pentium® 4 2.8GHz, 256MB, 80GB, 48x CD-RW PC Desktop Logo
373 people viewed this question
Clive
Clive
Alun Cox
