Jamming paper hi there when i photocopy the paper is jamming on a roller and a message appears F28 3 contact service department. I've tried turning the machine off and restarting - but it seems to jam in area 6 as marked on the diagram of my copier.
  • 4 more comments
  • gocab Dec 01, 2008
    Oops It is a Konica Danka 7022 copier.
    Tried- removed paper however when I copy again same problem and message
    Thank you - however the machine continues to jam even though I clear it (whole page) on roller.
    Tried to do as suggested- however same problem. Help!
    Konica Danka 7200
    Sorry it is a konica danka 7022
    Sergeant:
    Champion:
  • 283 Answers
If this does not fix your problem please dont rate me. Check the roller and allign it. Turn of the machine for couple of minutes then switch on the machine back. Try to photocopy.Post for mre details..Hope this could fix.Thank you...
Posted on Dec 01, 2008
  • 837 Answers
Could you tell us the make and model?
  • 10,515 Answers
This error has to do with the charging section. You can try turning off and on, but sorry, Gocab it is not something that can be resolved by an end-user. I am sure that there is someone locally that can work on the machine for you, even if it is out of warranty. Save your downtime and call a tech. Thnx.
  • taran_2005
    taran_2005 Dec 01, 2008
    hey, if u wanna give a shot :)
    f-28 codes deal with a corona unit arching.
    if its a f-28-1 its the charge corona on the drum unit. more than likely its a f-28-3 though which is a seperation corona arch. these models were notorious for the insulating material that transfers voltage from the machine, to the door then back to the corona would eventually break down and start casuing arching.
    what to look for, open the right side door and halfway down you will see a black peice of plastic sticking out that is attached by to screws. this needs to come off, but to get this off you will also need to remove the door opening bar. a total of 4 screws and you can have the black plastic peice in your hand. once off flip it over and open the back cover up. you will see 2 grey peicesof insulating material, one will be burnt the other will be fine. from here on it is up to you as to how you fix it. using an insulating tape that is cut to the opeing is an appropiate fix but it must be able to withstand high voltages. put it all back together and it should work.
    Thanx.
  • taran_2005
    taran_2005 Dec 07, 2008
    Is that issue resolved :(
  • 849 Answers
Yeah you have to open the copier where the area 6 is pointed in the diagram and clean the jam from there. the jam may be a piece of paper or a complete paper stucked there. some time u have to pull out the roller and tomer drum for such rectification.
  • 495 Answers
Try to remove the paper from the tray.Just open the front cover and try to take out cartridge in order to remove the paper. Machine will restart automatically.
  • Manoj Rout
    Manoj Rout Dec 01, 2008
    Can't you open your copier front cover, because for paper jam problems, you need to do it manually.
  • Manoj Rout
    Could you please check if you have put the paper properly, it could be because of paper alignment.
Kyocera TASKalfa 3050ci Photocopier paper jam 0100
remove the fuser and look for paper between the induction and roller systems or wrapped around the fuser rollers
Aug 11, 2014 | Kyocera Office Equipment & Supplies
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
Epson BX600FW Photocopier saying paper jam and we can't see any.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
May 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Message appear 'paper jam'
Have another look, especially the front rollers, all it takes is a small piece of paper in the right place, to get the error message. How do I know, cause it happened to me today.
Nov 07, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Paper jam message
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | Canon MX310 Office All-In-One Printer
The paper keeps jamming in my konica photocopier and the following message appears F28 3 Contact service department
F28 High voltage leak. (coronas)
The corona wires are arcing, it is located directly under the drum a unit with three thin wires. the end blocks go bad and it arcs causing jams and copy quality problems, replace the corona ***'y.
Other cause may be the High voltage unit for the coronas itself
check this site for the price
precisionroller.com
Dec 01, 2008 | Office Equipment & Supplies
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
