Question about Sharp MX-2700N Color Copier
Error code h4-01
Forgot to mention that the printer is a sharp mx-2700n, caN NOT ERASE ERROR MESSAGE....PLEASE HELP!
  • 5 more comments
  • info476 Dec 01, 2008
    what is sim 14?
    Thankyou....this has not worked!..where is the thermostat/fuser located please?
    Yes
    Yes it did re-boot but within 4-5 mins the error message appears......machine is also asking for a new toner cartridge....could this be aiding the problem?
  • Anonymous Mar 17, 2014
    MX-2700n error code E7-02
    PLease how do I service this code TK1??
  • 24 Answers
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
  • 3 more comments
  • John Edwards Dec 01, 2008
    Sim is short for simulation (this is the diagnostic mode for the copier)
    Sorry this is the exact process.
    Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
    Did the machine reboot when you put the code in and pressed the ca button?
    The fuser is in the right hand side door it is the very hot section. I would not attempt to fix this yourself.
    Here is the H4-01 error from the sharp manual
    Trouble content The temperature does not reach the specified level
    within the specified time after turning on the power
    relay.
    Section PCU
    Case 1 Cause Thermistor trouble, heater lamp trouble, PCU PWB
    trouble, thermostat trouble, AC power source
    trouble, interlock switch trouble
    Check and
    remedy
    1) Use SIM5-2 to check blinking of the heater
    lamp.
    2) If it blinks normally, check the thermistor and
    the harness.
    Check the control PWB thermistor input
    circuit section.
    3) If it is not lighted, check for the heater lamp
    disconnection and the thermostat breakage.
    Check the interlock switch. Check the AC
    PWB and the PCU PWB lamp control circuit.
    4) Use SIM14 to cancel the trouble
  • John Edwards Dec 02, 2008
    Asking for a new toner cartridge doesn't affect the error code, but might cause a problem once you have fixed the H4-01 code. The main problem is that your copier is not reaching the required temperture in the allocated time, this is "usually" caused by either a blown lamp or a tripped thermostat.
How do I print to the MX-2700n?
If you are conecting directly you should be using a usb cable and you will need to install print drivers from sharp usa.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Aug 29, 2014 | Sharp MX-2700N Color Copier
Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Jul 21, 2009 | Sharp MX-2700N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Call for service: code U2-05
i think that u2 shows some memory or eeprom problem just reset it .press clear key,exposure mode key,clear key,exposure mode key,press all these key in sequence and quickly.display will go dead now press 16 then start key.code will bi removed .mian jee
Jan 16, 2009 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error Message H5-01
H5-01 = detecting 5 consecutive POD_1N jams
Check the fusing section for jam paper. (winding, etc.)
Use SIM14 to
cancel the trouble.
enter 14
accpet yes clear..
To fix this you need to have the fusing unit looked at... could be various problems causing this , from bad paper to bad rollers?
Nov 24, 2008 | Office Equipment & Supplies
Sharp MX-2700N Color Copier Logo
803 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
