Question about Garmin eTrex Legend GPS Receiver
Entering map references manually
Please can you tell me how to manually enter map refs into my etrex waypoints so that I can create a route.
The project/waypoint info in my manual only refers to distance and bearing fields.
Am I missing the obvious as usual?
  • Garmin Master
  • 638 Answers
To enter a waypoint, either use Mapsource software and transfer to the unit, or else create a waypoint and then edit it to the proper co-ordinates.
Posted on Dec 02, 2008
How do I save a new waypoint on my garmin 76cx?
Hi!
From your User's Manual Page 7:
You can create waypoints using three methods. Press the Enter/Mark key while at a location, create a waypoint on the Map page or you can manually enter lat/lon coordinates.
TO MARK YOUR CURRENT LOCATION
Press and hold the ENTER/MARK key until the Mark Waypoint page appears. A default three-digit name and symbol will be assigned to the new waypoint. To accept the waypoint with the default information, simply select OK.
To change any information, select the appropriate field and press ENTER to open the on-screen keypad. After entering and confirming the information you wish to use for the waypoint, select OK.
CREATING WAYPOINTS USING THE MAP
On the MAP page, use the ROCKER to move the pointer to the map item you wish to mark.
Press and QUICKLY release ENTER/MARK to capture the pointer location and open the information page for the map item.
Select SAVE. If there is no information for this point, a prompt will appear saying "No map information at this point. Do you want to create a user waypoint here?". Select YES.
If you require a User's Manual, you can view/download it from:
http://www8.garmin.com/manuals/GPSMAP76Cx_OwnersManual.pdf
Hope this is helpful to you.
Good Luck!
Feb 27, 2011 | GPS
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
How to reroute my desination i am looking for
From browsing the manual (page 20) for your Garmin nüvi 350, it looks like you will be able to do this by creating the route in MapSource, saving it as a GPX file, and then loading it to your nuvi on an SD flash memory card.
The Nuvi 350 doesn't support custom routes. You can create waypoints (or custom POIs) for each location and manually pick waypoints as you travel, but there is no way link all the points together into a route. While you can upload a GPX file to it, it won't contain the route, just waypoints. When you pick a waypoint and tell the 350 to take you there, it's going to calculate the route based on the settings (ie, vehicle type, shortest distance, etc). It won't follow a predetermined route.
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
How top use a garmin etrex g p s
Your manual will tell you how to use waypoints, mapping to a waypoint, and how to do backtracking. If you don't have the manual, you can download it from the Garmin website www.garmin.com. Under Products > On The Trail, find your model of GPS. On the far right of the page, you will see a link for the manual.
Oct 15, 2008 | Garmin eTrex Legend GPS Receiver
Entering coordinates into a etrex yellow
Mark a waypoint, then edit the waypoint, entering the new co-ordinates.
Oct 04, 2008 | Garmin eTrex GPS Receiver
Garmin gps 60 .How do i clear all waypoints?
In your manual, on Page 23. Press ENTER on the waypoint to view the waypoint information page, scroll to DELETE, press ENTER and the waypoint is deleted.
Aug 08, 2008 | Garmin eTrex Vista GPS Receiver
How do I enter gps coordinates into my Etrex H
Mark a waypoint, and then edit the waypoint's co-ordinates. You can also create a waypoint in Mapsource and then transfer the waypoint(s).
Jun 29, 2008 | Garmin eTrex GPS Receiver
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
I've got a garmin E-Trex Vista CX and Mapsource software. After creating routes & waypoints (for Ben Nevis, Scafell Pike & Mount Snowdon) when I download these to the GPS unit each subsequent...
The contours are not coming from the routes and waypoints, they are coming from the mapping software. You must load all the map segments at once to your unit. You can upload routes and waypoints separately and they will not erase the other ones already on the GPSr unit.
Apr 21, 2008 | GPS
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
157 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
