Question about HP LaserJet 4000 Printer
Language selected not available massage on printer HP4000n
I have installed printer HP4000n on my PC using the prive PLC6 downloaded from HP website (US English). However, when printing the test page or anything of that matter the massage comes on printer as "Language selected not available". I checked all the options on the printer's drive and there is not a way to change language. Would you be kind to advice me of what to do.
Many thanks
  • sheribas Apr 24, 2009
    how to nstall a hp laserjet 4000n
  • 849 Answers
The language option is available in the printer menu.
Posted on Dec 01, 2008
Cant find scanner driver or software for hp 3055
Hi
Use a Normal TWIN driver that appears in any software that allows you to scan or in Windows click on Start, Device and Printers, Select your HP3055 and SCAN
Dec 09, 2014 | HP LaserJet 3050 All-In-One Printer
I lost the software disc to my HP Officejet 4500 Wireless Printer
Hi there!Here is the link with drivers for all operation systems http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3986394&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=3919445.
Just select your type of OS and download plc5 or plc6 driver.Feel free to ask if you need help.
Dec 17, 2012 | Office Equipment & Supplies
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
When I instal my Hp All-In-One then a massage come- Error1904,Module C:\Windows\system32\msxml4.dll failed to register. HRESULT -2147024770. Contact your support personnel. Please go to...
To resolve the problem A patch is available to download the patch go to the link below.
Once you click on the link select your printer model number and then operating system and then download the patch.
Download patch now
after you download it install it by following the screen instruction.
Nov 07, 2010 | Computers & Internet
What is a compatible software that i can use to install my hp laser jet 3300mfp all-in-one printer?
Start here:
HP LaserJet 3300 Multifunction Printer series support pages
You can download the drivers and software for your printer from here:
Download drivers and software . Select your software/driver language and operating system to see all available downloads for your system.
Oct 01, 2010 | HP LaserJet 3300 All-In-One Printer
I accidentaly changed the language, how do I get back to english
Go to the Printer Properties, Printing Preferences, or Document Defaults are Displayed in an Unexpected Language so trie changing the language from there if not then there are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
There are two ways to correct this problem. The first is to download the printer driver from the HP Web site and install it. The second involves replacing the .DLL file the printer driver uses to obtain the text that is displayed on the screen.
1. Uninstall the printer driver.
2. Run the Scrubber, located as shown below on the Starter CD, for the desired operating system.
1. For Windows 9x and Me: \UTILS\SCRUBBER\WIN9X_ME\SCRUB9X.EXE
2. For Windows 2000 and XP: \UTILS\SUPPORT\SCRUBBER.EXE
3. Download the latest version printer driver from the Internet and install the new driver.
4. If the properties are still displayed in the unexpected language, proceed to the Replacing the language .DLL file section below.
(To install the driver go to the hp website that is hp.com/support )
Select Start and then Search.
2. In the All files and folders box, type the name of the .DLL file and select Search.
3. Using the Explore window, locate the first occurrence of the .DLL on the hard drive.
NOTE: Replace each occurrence of the .DLL file in the \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\3 directory and any subdirectory where the file is found, \WINNT\SYSTEM32\SPOOL\DRIVERS\W32X86\hpdeskjet_6800421c.
4. Right-click the folder that contains the .DLL file to be replaced and select Paste.
5. Select Yes when asked to replace the file.
6. Repeat Steps 1-5 for each occurrence of the .DLL file that was found.
ALL THE BEST
Jun 02, 2010 | HP LaserJet 3030 All-In-One Printer
I power on my hp pavilion laptop and its in korean how do i change it
You are going to have to flash the bios to the english version and/or reinstall windoze to reset the language.
pls rate 4 stars
Nov 29, 2009 | HP Pavilion dv6000z Notebook
I dont have hp deskjet d2360 installer
You can download the driver and sofware (and the manual and instructions on how to install and use your your printer) from the HP support page for your printer:
http://h10025.www1.hp.com/ewfrf/wc/product?product=1100995&lc=en&cc=us&dlc=en&submit.y=4&submit.x=10&lang=en&cc=us
Click on the 'Software & Driver Downloads' link and then select your OS and language.
Sep 04, 2009 | HP Deskjet 2360 InkJet Printer
HP 5150 Printer Preferences in French
Here are the directions from the service manual.
Setting the display language
1 Press and hold [SELECT] while turning on the printer. Hold [SELECT] until SELECT LANGUAGE appears.
2 Release [SELECT]. INITIALIZING appears briefly. Wait for LANGUAGE=[(current elected
language)] to appear.
3 Press [- VALUE +] repeatedly until the language you want appears.
4 Press [SELECT] to save your choice. An asterisk (*) appears beside the selected language.
5 Press [GO] to exit the menu.
We have the full service manual available for $6.95 instant download if you are interested.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 09, 2009 | HP LaserJet 5100 Printer
HP LaserJet 4000 Printer Logo
143 people viewed this question
Ben Johnson
