Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
How do i get the backlight to go on again on my m240 sansa scandisk? thanks
    Scholar:
  • 161 Answers
On my C100 the backlight comes backon when I press the menu button.
Hope that helps.
Honestly.
Posted on Aug 26, 2009
I don't know how to delete all the music from my sansa scandisk m 240 device
the fastest way to do this is to connect it to your computer go into the computer screen right click on the device and choose format..
Jul 12, 2010 | SanDisk Sansa m240 MP3 Player
Scandisk Sansa M240 in stops transfering tracks at 8% on Napster
go to yahoo find a driver and then reregister napster it should work
Jan 18, 2009 | SanDisk Sansa m230 MP3 Player
DRIVERS PROBLE SCANDISK SANSA M250 2GB
Go To Start ---> Run ----> Devmgmt.msc which brings up the device manager. then see if any question marks are showing (the missing driver) if so , right click on it and select driver update and see if that works if now please come back here and we will continue further..
Dec 30, 2008 | SanDisk Sansa m240 MP3 Player
Help please
Try resetting everything back to factory setting or download its drivers from the official website and install them.
That should fix your problem!!!!
Thank You!!!!!!!!!!!!!!
Jul 03, 2008 | SanDisk Sansa m240 MP3 Player
Haw can I record and save? on SANSA of SanDisk
ok so go to menu record and then finish recording itll ask you if you want to
May 29, 2008 | SanDisk Sansa m240 MP3 Player
LCD screen on Sandisk M240 MP3 not working
it stays on the sandisk screen.its frozen
Dec 28, 2007 | SanDisk Sansa m240 MP3 Player
Scandisk sansa m240 mp3 player
You can manually transfer files thru My Computer>Device Name (m240). Just drop the files, no folders, into the device. Best of Luck.
Oct 04, 2007 | SanDisk Sansa m240 MP3 Player
Backlight problems
If its less than 1 year old, have it replaced. Otherwise, you may want to find someone electronically inclined to replace the internal led light. Best of Luck.
Sep 12, 2007 | SanDisk Sansa m240 MP3 Player
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
