Question about Jensen VM9510 Car DVD Player
DVD Playback Error
My vm9510 has been working fine for quite some time but, recently when I put a DVD into the player it either reads ERROR or EJECT Disk. Sometimes it'll play for a minute then freeze. I've tried different media from DVD to MP3 disk but I still keep getting either of these messages.
  • 944 Answers
Here is the link for the manual if you need it - ask again if you don't find what you need. http://audiovox.com/manuals/owners/VM951... Hope this helps :)
Posted on Mar 10, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 11, 2007
    Sorry was a bad link should be:
    http://www.audiovox.com/
    Click on Jensen, select multimedia, then select "older models" and half way down you will find the link to the manual.
    Hope this helps more:)
Why does my pye py 90DG does not accept any dvd(R-WR)?
Try reloading the driver for dvd player burner. If this does not work try downloading the "read program" for the specified dvd drive.
May 03, 2014 | Televison & Video
I got a nb501sl9.. doesnt play burned dvds.. says "please eject playback may not be a option.." tried burning firmware to update... still does not read the disc burned on dvd+r. Says the same...
Maybe this model does not support DVD+R, or the discs you have been using may not have been finalised in other equipment prior to playback in this unit.
Try using finalised DVD-R discs instead. They should work in this player, if not, then it probably does not support burned DVD media.
Nothing you can do, except purchase an el-cheapo DVD player (alongside this one) which can read DVD-R/DVD+R and other burned media.
May 01, 2011 | Sylvania NB501SL9 Blu-Ray Player
Disc Error: My question is a result of a recent problem that I have been having with your product and recorded DVDs. On certain movies, I have been able to play them with absolutely no difficulty. However...
some older dvd players dont play dvdrs very well, but most wont play dvd in pal format only ntsc some movies are recorded in pal, you can change format if you are using nero on the last stage wher you click burn choose ntsc
Apr 13, 2010 | Emerson EWD2204 DVD Player/VCR
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Mar 02, 2010 | Denon DVD-1740 DVD Player
Brake override Jensen vm9212
Are they "burned" DVDs? The brake override will only allow video to come through the screen it won't make the unit not read them.
Mar 01, 2010 | Jensen VM9510 Car DVD Player
DVD won't play
clean the laser lens first
Mar 06, 2009 | Philips DVP3050V/37
My phase linear uv8
Hi
The Laser Diode inside the UV8 that reads the DVD media is most likely set too weak for the amount of dust built up in over time. This dust block the laser optics and causes the player to not read DVD's. You will want to go get a bottle of air from Radio shack and blow the DVD player out. The reason it is reading CD's is that its laser diode may be set stronger and is able to break through the dust. There are two Laser Diodes, one for CD, and one for DVD. Good luck. www.PlaystationClinic.com
Sep 04, 2008 | Jensen VM9510 Car DVD Player
VCR WORKS,BUT DVD DOES NOT
Place a disc in the tray with the label facing up. Let it try to read. If the disc is still oriented the same way after it fails, odds are 99 out of 100 the motor has failed....sorry, buy a new one if warrantee has run out.
Feb 10, 2008 | Emerson EWD2203 DVD Player/VCR
EJECTING ERROR/LOADING ERROR
yes, i send it in to alpine and they adjust it for like $100 or so.
Dec 28, 2006 | Alpine IVA-D310 Car DVD Player
Jensen VM9510 Car DVD Player Logo
230 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
