Question about LeapFrog LeapSter L-Max Console
Leapfrog Leapster I bought my son this and initially the pen worked fine on the screen, but after a couple of months now it doesnt always work when touching the screen to get it to do things.My 4 yr old son has autism and is getting extremely frustrated when nothing happens, please can you help asap as this is the 2nd one we have got for him, the first one had the same problem and we took it back and got it changed. many thanks, catherine.
  • 9 more comments
  • Anonymous Dec 15, 2008
    When calibrating the screen does not respond in the center?? Now what??
  • ingramfam Dec 26, 2008
    I have the exact same problem. While calibrating the Leapster, the corners work but the center does not. Would it help to disassemble it or is it a lost cause?
  • Anonymous Jan 06, 2009
    Unit boots fine, when asked to enter usernames, can't do anything. I tried holding the 3 buttons simultaneously, didn't work. This is a Leapster2
  • Bill Wimmer Jan 12, 2009
    My son's leapster is only days old and the screen stopped working
  • mande0234 Jan 14, 2009
    I have the same problem. I've tried to calibrate however touching the screen with the stylus doesn't work anywhere other than the corners. For some games I've noticed that by waiting you may be able to bypass entering a name however that isn't always the case and then those games are useless. What can we do to correct this issue?
  • Thepopo Mar 07, 2009
    Exactly the same issue - corners are OK, but cannot calibrate the center.
  • Anonymous Mar 19, 2009
    I have the same touch screen problem. Tried both solutions suggested here (holding Home/Hint/B buttons and Hint button while powering on) to recalibrate. In both cases, touching the corners worked fine, but nothing happened when touching the stylus in the center. Is this a chronic problem with Leapster touch screens, or does it just wear out?
  • Anonymous Mar 24, 2009
    Excelent, Solution #2 works perfect on our Leapster 2...
    Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Apr 16, 2009
    I'm having the same problem, however when I go to the calibration option the screen says "starting touch calibration..." then the screen goes dark. The machine doesn't turn off, it just doesn't do anything. Any help would be greatly appreciated.
  • Anonymous Apr 26, 2009
    I did both approaches and neither worked. The hint-power option just left a blank screen. The home-hint-b at sign up causes "touch the center of the target" to appear. The target never appears.
  • babeet86 May 11, 2009
    I have followed all the steps to fix the stylus but for some reaon a target or crosshairs do not appear.
I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
1. Unit must be OFF and NO cartridge
2. Hold down the HINT (?) button while turning the unit on
3. When Leapster menu screen appears, press the A button
4. Touch each of the cross hairs that appear with the stylus
5. Restart unit
Posted on Jan 25, 2009
Thank by your help, the solution #2 fix my problem with the unit of my sister
Posted on May 03, 2009
Solution #2 worked first time for my daughter's Leapster2
Posted on Apr 17, 2009
Yes, this worked perfectly fine for me. thanks a ton.
Posted on Apr 07, 2009
The following are instructions for calibrating the Leapster™ handheld.(1) Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.(2) Hold down the Home, Hint and B buttons simultaneously.(3) When the screen changes, press the A button.(4) Using the Stylus, touch the center of the targets.
Posted on Dec 12, 2008
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
Screen is totally blacked out but the sound works.
leapster initially worked but now will not work, batteries are fine
Dec 25, 2009 | LeapFrog Leapster Learning Game System
Pen not working on screen to use
Hi, have you tried to recalibrate the screen as in your instructions?
Make sure you have no game inserted
Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
Press A
Now touch all the little crosses with your pen that appear on the screen
switch leapster off and restart
if still not working, repeat above
Jun 15, 2009 | LeapFrog Leapster 2 Learning System
Leapfrog Leapster touch screen
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Apr 10, 2009 | LeapFrog Leapster 2 Learning System
The touch screen on my sons leapster doesnt work.
Buy another one from the same store and just swap them.
Feb 20, 2009 | LeapFrog LeapSter L-Max Console
Leapster screen not working
Apparantly, the Leapster screen issue is a common problem. While this suggestion is not ethical and since my game was near perfect condition, I went to Wal-Mart and bought a new one of the same color and then returned the broken one.
Jun 12, 2008 | LeapFrog Leapster Educational Game: Disney...
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
LeapFrog LeapSter L-Max Console Logo
2,341 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Raymond Richards
Raymond Richards
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
