Question about Blaupunkt THA275 Car Audio Amplifier
No power to 6x9s ??
Hi just installed this amp and wired it up to the 6x9s and the woofers but theres nufin goin to the 6x9s any ideas?
    Genius:
  • 1,139 Answers
It looks like the internal amp compnents may have a problem. I would suggest getting a schematic and seeing if the audio can be traced from the input to the point of the problem.
Posted on Sep 08, 2007
Hi i purchased the bnps102 woofers and used them for 2 weeks i really enjoyed them and i also purchased the pyle 1400 watt amp and a jvc deck along with the boss amp kit installation now the speakers about...
If the lights on your sub box aren't coming on it's either your ground of power wire came loose or the transformer blew. As for the subs, make sure all the connections are good, especially on your RCA wires. If your amp is getting power, then check your speaker connections. Also, make sure to turn the gain know up. The gain knob is located next to the RCA input on the amp. Let me know if this helps.
Aug 21, 2011 | Pyramid BNPS102 Car Subwoofer
I bought a new car and it came installed with a amp and two fusion 12" woofer. The problem is that the woofer is getting constant power and it chews up the baterry overnight i think so their is no acc wire...
Wire the power connection from the amp to the fuse box that is only live when the ignition switch is switch on and or the accessory is on.
When the ignition switch is off then there won't be any power to the amp. Connect this power lead with its own in-line fuse and on the power side of the fuse box before the fuses.
Sep 08, 2010 | Audio Players & Recorders
Amp cuts out
could be an internal problem such as a relay or resistor or something of the sort
Sep 02, 2009 | Car Audio & Video
Alpine eq 3331 install
USE THE FOR CH RUN ALL THE SPEAKER THE MEANS TWO RCA ONE FOR FRONT AND ONE FOR REAR INTO THE AMP AND NON-FADE REAR-FOR YOUR SUB --POWER FOR EQ--[POWER 'REMOTE AND GROUND]
Mar 26, 2009 | Alpine ERE-G180 11-Band Car Equalizer
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Fitting 6x9
heyy andy should be simple as, quick question are you goin to use a amp?
Dec 19, 2007 | JVC KD-S6060 CD Player
Help me!!!! i have fitted this sub & amp but how do i fit a 2nd amp for speakers
youll need distribution blocks for second amp.this is the basic solution though.other things like wire guages,amp power and crossover settings need to be considered.
Aug 02, 2007 | Fusion FEW12PK Car Subwoofer
No Sound coming out of amp to subwoofer
check the fuse box and make sure there is no loose connection there. also check the wire that feeds power to that amp. good luck
May 23, 2007 | AudioBahn DUB Mag Audio DUB1002 Car Audio...
Need Wiring Help
how do u have everything wired for the amp and speakers?
Aug 27, 2006 | Ultimate Sound T3 Series 4320 Car Audio...
Blaupunkt THA275 Car Audio Amplifier Logo
67 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
