Propane fireplace insert won't light
I have a 6 year old Pyromaster unvented propane fireplace insert which has about 1 your of use on it.
Push button to get pilot light lit. Stays lit. When moving the round knob to ON, pilot light goes out and of course does not light fireplace.
I assume I'm getting gas since the pilot light lights.
Could something be clogged up ? or Could the electric starter mechanism has gone bad.
  • williewilcox Jan 18, 2009
    Same problem, but thermocouple is good what next??
  • ltextreme Mar 07, 2009
    I have the same problem. I replaced the thermocouple. Problem still there. Do I need to replace the thermopile?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
  • 41 Answers
The problem with replacing just the thermocouple or just the thermopile is that you are putting a new part with old parts. This can cause further issues and if the pilot assembly is older and you replace 1 part, you may have to replace another within a few months. I recommend you just go ahead and have the pilot assembly replaced. That way "all" of the parts on it are new and in peak operating condition.
Posted on Feb 02, 2018
I replace an old Dometic fridge with a new RM2620 last year. when I run propane the trailer smells of after burn propane. i have checked for leaks and can't find any. I think it is a venting problem?
Yes, I would check your venting. Shut it down and open the access to the back of the fridge. The venting should be apparent and clean of course. Propane has a high water vapor content and contains Carbon Monoxide and should not be burned unvented in small spaces. Good Luck
Jul 14, 2018 | Dometic Refrigerators
If I need to convert my Martin unvented fireplace from nature gas to lp cause I have propane already
You need a conversion kit. The igniter orifices are different for LP. Go to the stove store and ask for one for your model.
Dec 14, 2016 | Heating & Cooling
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a propane gas fireplace that will come on and then occasionally go off for a while, then come back on. It may do this several times in a row. The flames look normal when on and I am not low on...
There are several possible things that could cause this problem. Fiirst you said you are not low on propane so the first thing I would want to know is your primary heat source or water heater also propane? If so and they are upstream of your fire place when they cycle they may be shorting your fuel supply. Second are you on a one or two regulator system? If you are on a single regulator you may be trying to draw more fuel than supply line can deliver.Either way the first thing I would do is contact your propane supplier and have them do a pressure check on your regulators. Most suppliers will due this free or at a minimal charge,but checks or adjustments should only be done by trained personnel. Where I live we have two stage system and propane supplier takes care of tank regulator free and house regulator at our expense. Hope this helps you. Thanks.
Nov 04, 2010 | Heating & Cooling
Pilot light won't light on ventless fireplace
Ventless Gas logs, Vanguard, VS30PR. Propane gas
Pilot light stays lit various times, sometimes for several days then other times for a few minutes. Lights best when temp outside is below freezing. Pilot flame appears to receive too much air. How do you adjust the pilot flame? Is this done using two screws marked A & E? Do you have suggestions?
Thanks,
Ed
Jan 07, 2010 | Desa International Unvented Gas Space...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Light soot around propane fireplace vent
burners burning yellow , in complete combustion , blocked air ways to burner , it needs a service soon as poss
Dec 22, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
3,006 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
