Hey the amp audiobahn a8000t turns on then burns out the fuses
    Scholar:
  • 142 Answers
Audio output transistors are shorted. Time to see a technician.
Posted on Dec 01, 2008
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Nov 09, 2010 | AudioBahn A8000T Car Audio Amplifier
My A8000t amps red protection light is on checked
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
May 14, 2010 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Apr 20, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Jan 15, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
Solution
Sounds like you have shorted output transistors or IC'S There is one test is to disconnect all the speakers and see if they still blow. If they do then you need to have the amp fixed or replaced. If they dont blow try connecting up each speaker till the unit blows the fuse asjust maybe you blew out a crossover or a speaker or two?? If you have an active type crossover then I would check that device as well. Good Luck
Apr 22, 2006 | AudioBahn A8000T Car Audio Amplifier
 Grubhead
Grubhead
