Question about Canon PowerShot S400 / IXUS 400 Digital Camera
Memorycard have brought a new memory card compactflash for canoncamera powershot pro1 8.0 mps there is a message which says memorycard error, could you please give information on solving this problem...thankyou
  • phoenix88877 Dec 01, 2008
    thankyou very much for the help,its been a few months since this problem occured,it is like a cpc a tad complicated directions or not,you solution was convenient easy to understand and much appreciated if i encounter further or need assistance with using this camera you will be the first to know..i have friends,knowitalls telling me this,that and the other ????thankyou....
  • Anonymous Dec 04, 2008
    I have a canon power shot pro 1 and I have memory card error on the screen and w hen got to settings and Format and tryed to change it it responed to me as "Busy" dose this make sense to anyone as I am really confused on trying to make use of my camera
    HELP!!!!!
  • 4,806 Answers
Go into the camera's settings and "format" the card, this should resolve the problem
kind regards and and don't forget to rate us please
Posted on Dec 01, 2008
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
I just put in a new memory card into a Canon A590 that I bought on eBay. It powers up and everything else looks fine but I get the memory card error..I did unlock the memory card itself so that is not the...
1. Try to format the card in the camera. It should give an error when faulty.
2. Put the card in a pc with cardreader and download this testprogram.
3. Run this program to test the memorycard.
4. Delete afterwards the test contents or re-format it.
Aug 29, 2011 | Canon PowerShot A590 IS Digital Camera
Memory card error message
Cards are coming in different formats and it might be possible that you brought a card which is not suitable or functional with your camera. The other reason could be that we are having options to lock our memory card in digital camera and you might have taken out your earlier card without unlocking it. The system might be broken from inside and this could be a reason that you are still getting a message that memory card is locked. It seems possible based on problem you are sharing.
May 28, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Memory card error
is the memory card the right kind? is it the brand? did you push it in properly?
Oct 03, 2008 | Canon PowerShot A520 Digital Camera
Memory card error
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Sep 24, 2007 | Canon PowerShot A300 Digital Camera
Card Error
This is from Konicas site. don't know if this will be any help for you since you had posted a long time ago. you most like have a new camera by now. anyway. Question: When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the monitor display. Answer: Please follow the procedure below. While the message is displayed, press the center of the controller. The monitor display and data panel will turn off. Turn the Main Switch dial to OFF position and remove the CompactFlash from the camera. - When "No Card" message appears next time when the camera is activated in the recording mode, the camera and CompactFlash are OK. - When "Card Error. OK" appears again, the CompactFlash may be faulty. Use other card.
May 05, 2007 | Konica Minolta DiMAGE S414 Digital Camera
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
ERROR MESSAGE: Corrupted CompactFlash card.
Storing digital picture information to a CompactFlash card (as when a digital image is taken) is similar to storing data on the hard drive of a computer -- if the process is stopped or interrupted, the information stored is not complete and, therefore, "corrupts" the storage media. A computer will display a warning message indicating that the hard drive has errors, while a camera will display a message indicating the memory card is corrupted. The CompactFlash card corruption can be caused by: * Turning off the camera power before the photo information is completely stored on the card. * Removing the card before the photo information is completely stored on it. * Taking a second picture before the camera has finished storing the previous picture. * Camera batteries that are near the end of their life and need to be replaced. Once a CompactFlash card is corrupted, it can be used again only by performing a Format procedure. IMPORTANT! When a CompactFlash card is re-formatted, any pictures stored on it will be lost forever and cannot be recovered.
Sep 14, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Canon PowerShot S400 / IXUS 400 Digital Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
