SD-T43W1/SL pioneer rear Projector tv! Wont hold convergence when hot!red lines everywhere?
  • 4,234 Answers
There are a couple of possibilities here. First , poor solder connections at the convergence ICs. The heating up of the set will cause resistance changes that could cause the symptoms you are seeing. Or, defective ICs that when heated become marginal. If you can solder, try resoldering the pins of the convergence ICs first. Let me know if that helps.
Dan
Posted on Dec 01, 2008
My pioneer sd-p55a3 projection tv stays on for 5 minutes and then fuse for projector burns out
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Jun 08, 2010 | Pioneer SD-P55A3-K 55" Rear Projection...
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Hello, I have an older Pioneer SD-P55A3 projection tv. I have a problem where the picture at the bottom of the screen appears distorted or, more accurately, "warped". There is yellow and blue that does not...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-533hd5 convergance
for pictures on where is the convergence settings click on this given link.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
but if its the problem in convergence board then check out for this link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
May 08, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Alignment of color convergence
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 17, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Picture of rear projection tv
Convergence amp ic are bad.
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
Oct 13, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
