Question about Fuji FinePix F40fd Digital Camera
Hi my lens is stuck in the out position and zoom error is on the screen can you help finepix f40fd
  • 244 Answers
Lens needs to be removed, carefully stripped and re-assembled. If the three small plastic guide luggs on the inside slide ring are broken sell for spares. Very hard to repair.
Posted on Jan 25, 2009
  • 849 Answers
Chech batteries, els the gears of lense has damaged
Posted on Dec 01, 2008
Fujifilm finepix f40fd
The lens needs to be dismantled and reset.
If your camera is under warranty then fuji will replace for free. If not then it may cost around £90 to have the lens unit replaced.
Cost of repair will depend on where you take it to get it repaired and will undoubtedly be more than the cost of a new camera.
However.....
It can be repaired for as little as £30 if you look hard enough ;-)
Nov 13, 2009 | Fuji FinePix F40fd Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Hi, my zoom is stuck out and won't retract.
Your lens motor is most likely burnt out. The only way to continue taking pictures is push the lens in manually, You may have problems with the focus after doing this, so just turn the lens manually until you are zoomed in properly. If you have a warranty now is the time to use it.
Jun 26, 2009 | Fuji FinePix A600 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Lens error on camerafuji f601 finepix
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Dec 28, 2008 | Fuji FinePix F601 Zoom Digital Camera
Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Jun 07, 2008 | Fuji FinePix F40fd Digital Camera
Zoom error
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Apr 08, 2008 | Fuji FinePix E550 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Zoom lense stuck
The only solution is to replace the lens module.that module is very costly. hope it help
Aug 09, 2007 | Fuji FinePix F460 Digital Camera
Fuji FinePix F40fd Digital Camera Logo
585 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
