I just got a new board ASUS P5K3 and by accident bought ddr3 1666 but it only supports 1066 will the same memory still work in that board?
    Problem Solver:
  • 8 Answers
I recommend returning it and getting the manufacturer recommended ram... you may have all sorts of issues if you use the wrong memory... such as pc constantantly restarting .. or not starting at all.... or just crashing regularly.
Posted on Dec 01, 2008
I want to know the graphic card slot in the motherboard ASUS M2N68-AM-SE2. Whether it supports DRR1, DDR2 OR DDR3.
Hi, you can see the list here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM/#specifications
At this site you also find drivers.
Remember to select your operating system
AMD Socket AM2+ / AM2 Processors
for AMD Phenom™ FX / Phenom / Athlon™ / Sempron™
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
Support 45nm Phenom™ II CPU Chipset NVIDIA Geforce 7025/nForce 630a
System Bus 2000/1600 MT/s Memory 2 x240-pin DIMM, Max. 4 GB, DDR2 1066/800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*DDR2 1066 is supported by AM2+ CPU only Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage Southbridge
4 xSATA 3 Gb/s ports Support RAID 0,1,5,10,JBOD
ATAPI support ,AHCI mode
LAN RTL8211CL Phy Gigabit LAN Audio ALC662 High Definition Audio 6 -Channel CODEC
USB 10 USB 2.0 ports (4 on back I/O, 6 on board)
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCIe x1
2 x PCI
Storage Southbridge
1 x PCI-E x16 Graphic card slot.
Aug 25, 2011 | ASUS M2N68-AM SE2 Motherboard
Hello, i got maximus formula motherboard. CPU : LGA775 socket for Intel Core 2 Extreme / Core 2 Quad / Core 2 Duo / Pentium extreme / Pentium D / Pentium 4 Processors Chipset : Intel X38/ICH9R FSB...
This is your board by the numbers you supplied:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131199
You have Via P4M900 and VT8237 chipsets and Realtek ALC662(sound)
This is Asus's link for your board:
http://www.asus.com/Motherboards/Intel_Socket_775/P5VD2VM_SE/#download
It's supported to Windows Vista so, it may or may not work with Windows 7.
You can try your sound here, if necessary:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
and, this is Via's link:
http://www.via.com.tw/en/support/drivers.jsp
It appears your board has the support for Windows 7, if that is what you are running so these should be all you need. Let me know if I can help you further.
Dave
Jul 17, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Want to add ddr3 memory to my p5qc board
Hello
The motherboard supports DDR3 1333/1066/800 MHz or DDR2 memory 1066/800/667 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3/DDR2 architecture doubles the bandwidth of your system memory to boost system performance, eliminating bottlenecks with peak bandwidths of up to 19.2 GB/s.
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel
2 x DIMM, Max. 8 GB, DDR3 1333/1066/800 Non-ECC,Un-buffered Memory 4 x DIMM, max. 16GB, DDR2 1066 / 800 / 667 MHz, Non-ECC, Un-buffered memory Dual channel memory architecture When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots! Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists). When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Hope this helps
Jan 19, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
My asus m3n78-em motherboard does not boots with 6 gb ddr2(3 chips of 2 gb) ram it works properly with 4 gb ram(2 chips of 2 gb) i dont know what to do it used to work properly before but its not working...
This board has a dual channel memory. To function correctly both channels must be identical otherwise , as you can witness, it chokes. To put it simply you must put either 2 identical sticks of memory or 4 - it can't run on 3.
Jun 16, 2010 | Computers & Internet
Just installed 2gb more memory on asus p5k3 (6 total) and vista only sees 4gb. Is there a jumper to pull? Thanks, Steve
are u using vista 64 bit cause if ya not thats your problem 32bit platform digitally maxs out at 3 or 4g u need 64bit to go higher
Sep 21, 2009 | ASUS P5K3/P5K (P5K3 DELUXE/WIFI)...
Powering up
You need to remove the cap from 8-pin EATX12V connector and connect 8-pin EPC +12V power plug from your P/S, otherwise it will not work. Your power supply should support 8-pin EATX12V. If you P/S comes with 4-pin connector only you just use your 4-pin open spot and leave the cap on.
May 22, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Wont post with 1333 fsb
This board wont take a 1333 cpu. The fastest it will run is 1066
This motherboard supports the latest Intel® Pentium / Celeron CPU in LGA775 package with 1066/ 800/ 533MHz FSB, Hyper-Threading Technology and core-speeds up to 3.8GHz and beyond.
Make sure your RAM is DDR2 800mhz
The Pentium D830 runs at 800fsb which is in line with the board capabilities.
Feb 24, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
