Question about JVC GR-DVM50 Camcorder
I am poor - JVC GR-DVM50 Camcorder
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 39 Answers
GET A JOB
Posted on Dec 01, 2008
Looking for a gospel song that has the lyrics "shake hands with a poor boy who owns everything" in it.
Shake hands with a poor boy that owns everything
Shake Hands With a Poor Boy - Kingsmen Quartet
I've never had much, in this world below
But I'm going to a city, where the streets are pure gold
Christ made me an heir; I'm the child of a king
Shake hands with a poor boy, who owns everything
2nd verse
I'm depending on heaven, for my home in the sky
Already I'm heading, for that sweet bye and bye
But I've been adopted, and placed with a king
Chorus:
Shake hands with a poor boy, and how do you do
Have you met my Father? He cares about you
He's the king of all glory, His praises I'll sing
Shake Hands With Poor Boy With Lyrics
Jan 07, 2016 | Computers & Internet
Poor picture quality
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Replaced motor, starting hard. runs fine . how do I check fuel pressure
Doubtful you have a fuel pressure problem if the car runs well, poor starting can be a few things , poor air circulation air filter needs cleaning or replacing, poor injector flow warn injectors or just dirty fuel additive sometimes clears this , poor spark plugs not firing under pressure ok when started . for diesel cars you don't say what car it is , poor glow plugs . bad fuel filter , air leaks in fuel pump , poor injectors . and especially with diesel poor compression due to worn rings or head gasket failure . You may even have just have disturbed the engine earth strap when you replaced your starter motor .
Jul 03, 2015 | Cars & Trucks
93plymouth voyager failed smog high NOX check eng lite not on . But I did pull codes 34. 43. And 55. Egr is working but maybe not enough .can you please help.
too much oil??? or a bad oil seal or oil way
bad air filter
poor fuel mix
poor ignition advance...{vaccumes}
contamination in the fuel tank
bad inline fuel filter
poor back preasure {bad manifold or exhaust}
bad ignition system
etc.,..
all leed too a poor mix and bad nox
Sep 09, 2014 | 1993 Plymouth Voyager
I have 2 radios mp1000&990 the 1000 is working purfect but the receive on the 990 is very poor why is this what shall ido
I couldn't find mp990 or mp 990 radio anywhere on the web. If you're not going to do your own Google or DuckDuckGo search then you need to supply enough information so someone else can do the search to help you.
There are two basic reasons any radio has poor receiving
1. The receiver design is poor
2. Something has gone wrong.
If you have more than one mp990 and all are poor then the receiver design is poor. If only one is poor then the radio had been damaged.
If these are inexpensive FRS radios then chuck it and buy another. If it is an expensive radio try to find some place to have it repaired.
Good-luck
Oct 26, 2013 | Radio Communications
1999 mountaineer 5.0v8 awd a/t poor poor poor gas mileage 10mpg @ hwy speed 55mph ! What can be so wrong ? Help randallalt@aol.com thank U :-)
poor gas mileage with any vehicle is usually due to lack of maintenance.
options to try:
replace fuel filter
replace air filter
spark plugs
timing adjustment?
let me know if any of this helps
Sep 20, 2013 | 2005 Mazda B2300 Regular
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
Has fuel and spark but wont fire engine turns over so starter ok
If by what you mentioned is right the engine should fire but there is an issue and could be relative to poor intensity of spark, poor plugs, poor fuel delivery and finally poor TIMING.
So you need to check the above one by one to confirm the fault.
The use a good timing check is important, so also to check the spark plugs.
Feb 02, 2011 | 2000 Harley Davidson FXD Dyna Super Glide
Distorted sound
Poor signal or poor connection to the cable probably. Could also be a speaker issue or the audio board on the tv is failing.
Most likely just poor signal or poor connection on the cable.
Oct 13, 2009 | Toshiba 42H81 42" Rear Projection...
Poor picture. looks like a negative. poor
If you go into the menu there should be an option to change the brightness and sharpness of the image
Sep 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
JVC GR-DVM50 Camcorder Logo
44 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
