Question about Rival 38601 Smart Pot 6-Quart
Broken Lid handle
I have used my Smart Pot to cook for the family for just over a year. I'd say we use it about two to three times a month. The plastic handle just fell apart this morning when I lifted the lid. Where can I get a replacement handle?
  • 14 more comments
  • Anonymous Nov 02, 2007
    i need to order a new lid handle
  • slowcooker Nov 05, 2007
    screw has stripped our and won't hold the handle securly. Super glue and using teflon tape doesn't work - what now?
  • Anonymous Nov 18, 2007
    I have the rival 38601 crock pot and the handle has broken off the lid and was wanting to know how to get a replacement, please help.
  • Anonymous Nov 19, 2007
    I am very upset that I went to hand wash the lid to my crock pot & the handle off the lid just broke off.
  • ragsie Dec 12, 2007
    While checking the contents of our dinner cooking in the 6 qt. rival crock pot the handle just broke off. How do we get a replacement? Bob
  • Anonymous Dec 15, 2007
    My lid came off when I lifted it.
  • cook123 Dec 15, 2007
    I have a model 38601 and the plastic handle has broken off the lid. Where can I get a replacement lid for this model? I have searched rival's web site and cannot find this particular lid model.
  • Anonymous Dec 19, 2007
    I need just the handle, not the whole lid. I did check out the abtec site, but do not care to spend $15 for a whole new lid when I only need the handle!
  • MBlackburn Mar 03, 2008
    I have a smart pot crock pot. I have used it maybe 10X. The lid is broken. I have tried to glue it, didn't work.
  • Anonymous Mar 08, 2008
    I use my crock pot minimum of two times per week. The black loop handle on top of the glass cover keeps coming off. I feel this is a manufactur defect. My husband has super glued it back on numerous times,it is only a temp. fix. I would like a replacement lid if the problem has beeen eradicated, or a voucher for a new crock pot. My patience has gone with this recurring problem.
  • the_edmonds1 Jun 29, 2008
    We have onlly had our smart pot for a couple of months and the handle broke. Where can we buy a replacement.
  • cwatson1950 Jul 14, 2008
    I HAVE TWO 6-QUART CROCK POTS, ONE WHITE & ONE STAINLESS W/ BLACK LID. ON BOTH OF THEM THE HANDLE HAS BROKEN OFF FROM THE HEAT. SURELY THIS IS A FACTORY PROBLEM
  • farmmom Jul 17, 2008
    I too haven't used my Rival Smart Pot very much and the handle to the lid broke.  I also tried glue and that didn't help.
  • mtanocaro Jul 18, 2008
    I went to lowes hardware and bought two (2) wooden 1-1/2" drawer knobs an stainless steel sheet metal screws #10x 1". I used the existing fiber(?) washer and screwed the knob to the lid through the existing hole. Seems to work fine.
  • Anonymous Jul 21, 2008
    I have the same problem and it's brand new. I had only used it a few times and the handle came off. Glue doesn't work because of the heat. Shouldn't Rival send us a new lid? I will pursue...
  • hyreco Jul 21, 2008
    How can I get a Lid Handle for my Rival Crockpot Slow Cooker?
Call the manufactur, they have replacements
Posted on Jan 17, 2008
My lid broke too. I found a replacement here http://www.abtecparts.com/commerce/search/products/?product_id=11XRI7921000021883&merchant_id=1933 I will be ordering it today.
Posted on Mar 15, 2007
    Problem Solver:
  • 9 Answers
We had the same problem with ours , if you have the time and patients you can repair these quite easy . I am the come to when something is broke since I do this on a daily basis. This method will work on most if not all brands of slow cookers with plastic handles
For these repairs I recommend JB weld , the industrial will endure heat up to 500* the handles should not ever hit that high so it is safe to use . ( I do not have any links to them this is from personal experience only)
Things you will need to do this project :
The major pieces that are broken ,
JB weld (found at most stores like lowes , home depot , or even walmart in automotive)
Disposable plates (you will need several )
Disposable spatulas (popsicle sticks worke well for this)
Tooth picks
1 flexable cutting board (can be found at most dollar stores in a 2 pak)
Sand paper in several grits from the roughest (100-) to the silkiest (320+)
Paint grille paint works well
Items you may wish to use :
Bamboo skewer
Hot glue
You will understand the above shortly .
Clean work area that will allow you to spred out and not be disturbed during the curing times
Start out by finding the major peices of the broken part in this case the handle. Next clean a work area off , take a disposable paper plate or such spread two (2) equal parts of the jb weld on to the plate take a disposable spatula such as a craft stick , and mix the epoxy is off white and black so when it mixes it will be a grey color . Mixing takes just a few short minutes to do . Take your parts and make sure you have them lined up as they need to go take a tooth pick and spread this on to the pieces that need to be joined both sides . Place them to gether , wait a few minutes and spread a bit onto one side of the broken piece . (If you have multipule peices becareful to not get the epoxy on the edges of those pieces you will have to do the the steps seprately , if it is just 2 pieces it is not as bad) spread the extra over the parts squeeze them tite and let sit over nite in a cool dry area under 80* with low humidity to aid in drying , curing time is about 72 hours or so .But you can hand sand down the epoxy after about 12 hours DO NOT put alot of pressure on it , it is still not fully cured ! Flip the handle over and do the same , but remember you are just looking to rough it up a bit dont worry about scuffing up the plastic , Next mix a bit more and try to spread a level layer over the first bit of epoxy extend out a bit .. Flip over and add an addtional layer on the underside sit it down and go about your day , after a few days you can sand it smooth check for any pieces that need filled in and do so at this time . Follow the curing times again and the sand down as above . Once you acheive the repair you want and the smooth finish it is time to wash under cool water and let air dry over nite . Next day , take the bamboo stick and the hot glue (hot glue is not permanate on metal ) , place a glob of hot glue in the screw hole place the skewer in let cool now you have a handle on your handle and you have protected the screw hole . Take out to a well ventalated area and paint allow to dry add a second coat if needed per the directions on the paint . Once you acheive this and your paint is fully cured you can remove the skewer and hot glue by picking it out , hand wash and return the handle to your lid . VOLIA it is fixed for not alot of money . Once you do this you will be amazed at the uses for the epoxy and how very easy it is to do !
Posted on Sep 16, 2008
I need the user instructions for use
Hi and welcome to FixYa, I am Kelly
I see I am nearly a month late in replying to your post. I just answered another post and when I finished I saw your question.
This is driectly from the user's manual that you can find here with some difficulty:
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(Avoid answering questions by looking for the blue text that says "security code" and clicking that) Then enter the 4 digit code to download the manual that is 209k)
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot slow cooker. The Power light will begin to flash indicating that the unit is plugged in, but not turned on.
3. Push the Cook Time button to scroll through the timed cooking options. Push once and the 4 hour light will illuminate, twice and the 6 hour light will come on, etc. Select the time based on the length of time indicated in the recipe. Two time options are usually given. The 4 and 6 hour settings are the HIGH temperature setting and may be used when you want your food done quicker. The 8 and 10 hour settings correspond to the LOW temperature setting and is used for all day cooking. In addition your Smart-Pot can be set to the Warm Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot slow cooker will automatically shift to the Warm setting and the Warm light will come on. NOTE: We do not recommend using the Warm setting for more than 4 hours.
5. To turn the Smart-Pot off push the OFF button. Unplug unit from the wall outlet.
6. For other recipes that give a range of times, select the time closest to the setting on your Smart-Pot. For instance a recipe calling for cooking time of 7 to 9 hours on LOW, set your Smart-Pot to 8 hours.
NOTE: If power goes off then power light will blink and settings must be reset. If cook time is changed before the cycle is complete the time will reset to the new setting.
That is pretty much the entire user instructions. Everything else is warnings, cautions, and oh yes; don't submerge it in water yadda yadda....
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Rival 38601 Smart Pot 6-Quart
Rival 38501 Lid
To contact the manufacturer, try calling 800 #. 1-800-323-9519 (US number) for replacement parts or try www.crockpot.com
iF YOU NEED PARTS CONTACT THE FOLLOWING SELLERS:
Rival Crock Pot Replacement Parts from MarBeck.com
Crock Pot Replacement Parts | Slow Cooker ...
Nov 03, 2008 | Rival 38601 Smart Pot 6-Quart
Handle on Lid is Broken.
Try one of the following sellers:
Oct 27, 2008 | Rival 38601 Smart Pot 6-Quart
Corningware Electrics Crock Pot Model SCO-150 Replacement Ceramic Bowl
Wanna sell your lid? I broke my sisters at a family reunion and I hate to leave her with half a cooker.
Margaret in SC for family reunion.
414-630-0040
Oct 04, 2008 | CorningWare K5607 Slow Cooker
Need plastic handle on Rival Crockpot lid.
I am Jo Anne Gomez who posted original problem and thought the problem was resolved with husband putting on a knob he found at the hardware store. Just wanted to let you all know that the handle we thought would solve the problem DID NOT....after he replaced the knob and we did another roast in it the lid totally shattered after we'd cooked another roast (luckily the glass did not get into the food), however, this is just a BAD PROBLEM and these lids should ALL be recalled. I have seen, just recently, the exact same crock pot and lid being sold for much less. I think that these crock pots should not even be sold but taken off the market to prevent lawsuits or horrible problems. Just wanted to let you know our solution did not work and Rival was not helpful at all.
Jun 23, 2008 | Rival 38601 Smart Pot 6-Quart
Lid not a tight or smooth seal
Hi, I have a Durabrand Slow Cooker and before that I had a Rosemary Conley one, both had loose fitting lids but this did not affect the cooking etc. I think that is the way they are meant to be. Use a non slip mat too as this may help, mine never vibrated even on high. Maybe you should get someone to look at it for you.
Jan 22, 2008 | Rival 38501 Smart Pot 5-Quart
SONYSP
Google is your best friend!!.
Placing, RIVAL, crock pot, parts brought up dozens of parts resellers, as well as Rival itself.
Jan 18, 2008 | Rival 38601 Smart Pot 6-Quart
Replacement cover for Rival 38601 Crock Pot
No, dont throw it away!!! You can use tin foil as a lid - I do this all the time as my lid shattered too and it works perfectly. You dont have to adjust times or anything.
Dec 09, 2007 | Rival 38601 Smart Pot 6-Quart
Rival 38601 Smart Pot 6-Quart Logo
606 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
Irene Tulloch
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
