Air not warm enough
Rheem Gas furnace troubleshooting:
When the unit kicks on, its just not warm enough. And it kick on about every 10 minutes. its like the heat exchanger doesn't get hot enough.
  • 61 Answers
You need to verify gas input pressure with a gas pressure test kit and also check heat exchanger for soot build up.
Posted on Dec 01, 2008
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
Rheem heater kicks on and shuts off about a minute later. then dose not come back on.
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Jan 23, 2011 | Heating & Cooling
I have an amana furnace and it will not kick on. When the switch is turned on the furnace will try to run but won't warm up and blow. Does it have a pilot light?? or a reset button??
Try this----turn furnace off at stat and unplug furnace for 10 minutes. Plug it back in, the combustion and blower motor may both kick on for 2 minutes or so or not. Turn t-stat to heat and turn up stat to highest setting. Hurry out to furnace and you should hear the combustion motor(little motor piped to flue) kick on, then wait for a "click" next you should see a glow from the igniton element, then another click, next will be the gas valve opening. If no ignition, it will try 3 times and then lock ur *** out, and just turn on the blower just as a precaution. If you dont see the glow plug glowing after the first click, replace the $20 glow plug and you should be good to go. The glow plugs crack, and this is what breaks the connection. If you gas valve has a knob, and says pilot----turn the valve to pilot, push down on the knob, light the pilot and hold down knob for 2 minutes to heat up flame sensor. Make sure the t-stat is all the way down or off. After 2 minutes of holding pilot knob down, let go and your pilot should be still lit, if it is, then turn gas valve to ON and then turn t-stat up to kick on furnace. If ur pilot doesn't stay lit, get a new thermal couple and replace it-$12 bucks. Good luck and let me know how it went. azeddysac@yahoo.com
Nov 06, 2010 | Heating & Cooling
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
My Rheem gas furnace will not kick on at all when set to auto. When I mannuly turn it on it does not put out warm air it just blow cold air.
Sounds like you may have an error code stored on the control board. Look for a small viewing port and look into the furnace cabinet for a blinking light. Once you find the light, remove some of the front panels and look for a wiring diagram pasted on one of them. There should be a diagnostic chart on the wiring diagram assisting you to pinpoint the area of the furnace that has an error. Good luck!
Mar 14, 2010 | Heating & Cooling
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
