My washer works perfectly, except that it comes to a "slamming" stop when the spin cycle ends. The intensity of the slamming seems to be getting worse. Help?
Gayle, sounds like your trans-brake assy. is binding up. I would remove the front panel, push in on the two clips just below the top on each side and pull the panel forward. Take a look under the tub and see if it has been leaking onto the trans-brake assy. You will see water marks or rust if so. If this is the case, trans should be under warranty for 5 years. If it's out of warranty, I would not invest in fixing it. Part number for the assy. is WH38x55. Look it up on the net and check it out...Catriver..post back.
So, while looking in the washing machine, I finally looked up rather than down and realized that at least one of the damper straps was broken. Upon further inspection, I see that at least 2 of the straps are broken. I'm going to replace those and hope for the best for now.
This was a used washer that I purchased.
I now know never to buy a GE washer/dryer, especially not used. The mechanical parts inside are also a bit rusty. Is there anything I can/should do about that?
Thank you for all of your help!
I am washing on a 30min cycle and can't change the intensity button from normal to intensive, why
