Sharp AR155 no detect for LGL size
Good day!
We have Sharp AR155. Our problem is, if we use the cassette tray, the detect is only for LTR size. If the original is LGL the copy scan is only LTR. Also if we use the cassette tray and we want multiple copy using LGL, the print out came out only by one. Maybe there's an adjustment for the cassette tray.
Please help us.
Thanks
chosen1copy
  • Andy Bebb May 11, 2010
    Hi, is this when you copy from the glass, or when using the document feeder (if fitted)
  • 66 Answers
Set the paper size
Posted on Oct 26, 2009
Konica Minolta BH164 Copier gets paper jam in LGL and FS size papers only what to do
then place the LGL and FS in tray one does it work??? is this printing or copying???
Jul 11, 2016 | Konica Minolta Office Equipment & Supplies
I have a paper jam at the back of my printer, where do i open it
Hopefully this will help you. Good luck !
Causes of jams
NOTE If you are experiencing jams in the duplex paper path, make sure that the duplex-tray
lever is set to the correct media size for your country/region. Open the duplex-paper-path door
and look at the embossed arrow on the lever. Make sure that it points to the media size for your
country/region. If the size needs to be changed, push the lever all the way in for duplex printing
on letter- and legal-size media, or pull it all the way out for duplex printing on A4-size media.
A4
LTR,
LGL
A4
LTR,
LGL
Occasionally, paper or other print media can become jammed during a print job. Some causes include
the following events:
? The print media that is being used does not meet HP specifications.
? The media is damaged or has objects attached to it, such as staples or paper clips.
? The environment in which the print media was stored is too humid or too dry.
? The input trays are loaded incorrectly or overfilled, or the media guides are not set correctly.
? Too many sheets have accumulated in an output area, or sheets are blocking an output area.
? Media is added to or removed from an input tray during a print job or an input tray is removed from
the all-in-one during a print job.
? The cartridge door is opened during a print job.
ENWW
Mar 13, 2015 | HP LaserJet 3300 All-In-One Printer
Half picture when making copy in A4
A4 is not a US size if you choose A4 the paper must be that size--
US uses Ltr-- Lgl and 11X14.
Dec 11, 2012 | Sharp AR 163 Copier
Paper jam problem
Replace the paper pick up & paper feed & paper sep. rollers in the paper tray... Good Luck
Sep 01, 2012 | Canon iR 2016i Black and White Copier
My MF5770 display alternates between "Change papersize" and "Check papersize" and will not print. Turning off does not solve the issue, nor does going thru' the menu to change...
You have to check both trays, the cassette and the manual feed:
The Cassette:
Remove the paper tray and inspect everything.. remove the paper, move all of the paper guides and make sure they all lock into place where they should (LTR, LGL, etc)
if the paper size guides are broken/damaged then the machine may not be able to correctly tell the size.
The Manual Feed:
Open up the front door, remove the toner and check the area around the manual feed. You're looking for the flag that tells the machine there's paper in the MFT. If this is stuck it's possible it's incorrectly trying to pull from there.
Jun 01, 2011 | Office Equipment & Supplies
How can I found out the stats on a Canon NP 6551 (ie total pages, etc...)?
NP6560 Main Specifications
Main Unit
Type: Console
Platen: Stationary
Photoconductive material: Amorphous Silicon
Copying system: Electrostatic transfer system
Developing system: Toner projection system
Fixing system: Heat roller system
Acceptable copy stock: Paper drawer:17 to 24-lb bond (64 to 90 g/m2); plain paper
Stack bypass:17-lb bond to 110-lb index (64 to 200 g/m2); plain paper
(However, Keep in mind that the paper weight that can be used varies
depending on the type of the Sorter being used.
SADF tray : transparencies and labels
Acceptable originals: Sheets, books, and three-dimensional objects (up to 4.4-lb or 2 kg)
Maximum original size: 11" x 17"
Copy sizes: Paper drawer: STMT, STMTR, LTR, LTRR, LGL, and 11" x 17"
Stack bypass: 4 1/8" x 5 7/8" (horizontal placement) to 11" x 17"
Non-image areas: Leading edge: 1/4" (4.5 mm)
Left and right side: 1/16" (3 mm)
Trailing edge: 1/16" (2 mm)
Warm-up time: Approx. 6 minutes (at temp. of 68°F)
First copy time: Max. 2.8 seconds
[LTR size, direct copying, Manual Exposure Control, Drawer 1 (top
drawer) selected 1→1-sided mode]
Copy speed: Direct (100%) LTR 60 cpm
65 cpm (Accelerated mode)
LTRR 49 cpm
11"X 17" 30 cpm
LGL 40 cpm
STMT 60 cpm
STMTR 60 cpm
Reduction 11"x 17" → STMT 56 cpm (50%)
11"x 17" → LTR 48 cpm (64%)
11"x 17" → LGL 40 cpm (73%)
11"x 15" → LTR 48 cpm (73%)
LGL → LTR 49 cpm (78%)
Enlargement LGL → 11"x 17" 30 cpm (121%)
LTR → 11"x 17" 30 cpm (129%)
STMT → 11"x 17" 29 cpm (200%)
Magnification: Direct 1:1.000
Reduction 1:0.500 (11" x 17"→STMT)
1:0.647 (11" x 17"→LTR)
1:0.733 (11" x 17"→LGL/11" x 15"→LTR)
1:0.786 (LGL→LTR)
Enlargement 1:1.214 (LGL→11" x 17")
1:1.294 (LTR→11" x 17")
1:2.000 (STMT→11" x 17")
Zoom 1:0.490-1:2.040
7-8
Paper feeding system: Drawer 1, 2 (1,500 sheets x 2)
Drawer 3, 4 (550 sheets x 2)
Stack bypass (50 sheets; stack approx. 1/4" high)
Multiple copies: 1-999
Power source: 120 V, 60 Hz
Max. power consumption: Less than 2.0 kW
Dimensions (H x W x D): 46" x 25 3/8" x 28 1/2"
(1169 x 643 x 725 mm)
Installation Space (W x D): 40 5/8" x 28 1/2"
(1030 x 725 mm)
50 3/8" x 28 1/2" (1280 x 725 mm)
[With copy tray (option) attached and stack bypass auxiliary tray extended]
Weight: Approx. 462 lb (210 kg)
RDF (Standard equipment)
Originals: STMT to 11" x 17" size (STMT-size cannot be placed horizontally.)
Original tray: LTR 15-lb to 110-lb bond (52 to 200 g/m2)
11" x 17", LGL, LTRR, or STMT
15-lb to 32-lb bond (52 to 128 g/m2)
SADF tray: 11" x 17" to STMT
11-lb to 110-lb bond (38 to 200 g/m2)
Max. power consumption: 120 W
Original tray capacity: Original tray: 11" x 17" or LGL
50 sheets (20-lb bond or 80g/m2)
LTR, LTRR, or STMT
100 sheets (20-lb bond or 80g/m2)
1 sheet
Original replacement speed: 60 sheets/minute (LTR, horizontally placed)
Power supply: 24 V (supplied from main unit)
Dimensions (H x W x D): 6 7/8" x 25 3/8" x 21 1/4"
(174 x 643 x 539 mm)
Weight: Approx. 56.3 lb (25.5 kg)
These specifications are subject to change without notice.
8-1
ar
Energy Saver
Stop
Guide
Additional Functions
Start
Display Contrast
ii
Enter a ID number with the Number ( 1 - 0 )
keys.
MEMO: ? If you make a mistake entering an ID number, press
the C
Clear
key. Then, enter the ID number again.
? You cannot enter two identical ID numbers.
? If you enter and store "000000" in place of a current
ID number, that ID number is canceled.
? You can store up to 1,000 ID numbers.
Press the [OK] key.
If you want to store another ID number, repeat
steps 3 to 5.
5
After entering all the ID numbers to be stored,
press the ID key. The display returns to the ID
entry screen.
6
Canceling the ID Mode: Clearing All ID Numbers
If you clear all the ID numbers then you can make copies without having to enter an ID
number.
Press the Additional Functions , ID , Stop , and Additional Functions keys in that
1 order.
Clear
Guide
Interrupt
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
iii
Press the [OK] key.
MEMO: ? If you want to stop all the ID#s from being cleared,
press the [C] key.
Press the [CLEAR ALL ID#s] key.
Press the [STORE USER ID#] key, then press
the [OK] key.
All the ID#s are cleared.
If you press the [OK] key, you will return to the
Standard mode.
MEMO: ? Storing all the ID#s under "000000" will also clear all
the ID#s.
iv
In the ID mode, the copier keeps track of the copy quantity made under each ID number (up to
999,999). You can view the copy total for each ID number in the touch panel display.
1 order.
After pressing the [COPY TOTALS] key, press
2 the [OK] key.
Press the [?] or [?] key to check the copy totals
for a department. The copy totals can also be
displayed by entering the department number.
Press the Number keys ( 1 - 0 ) for a four digit
department number and it appears at the top of
the display. When you finish checking the copy
totals, press the [OK] key.
Copy Totals (Check Totals)
The following procedure describes how to clear the copy totals for all ID numbers to zero.
Copy Totals (Clear All Totals)
1 order.
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
Reset
Clear
Energy Saver
Stop
Guide
Start
Display Contrast
v
2 the [OK] key.
Press the [CLEAR ALL TOTALS] key. 3
Press the [OK] key.
MEMO: ? To cancel clearing all totals, press the [C] key. 4
The copy totals for all ID numbers are cleared to
zero. If you press the [OK] key the display
requesting the entry of an ID number appears.
MEMO: ? You cannot clear the copy totals for ID numbers
individually.
Dec 21, 2010 | Canon NP 6551 Black and White Copier
Changing Image Size
It may sound silly, but it may work. When you inlarge the LTR page, is it cut off? Try placing the page to be copied or enlarged on the copyboard glass going in the LTR-R direction.. Good Luck
Jun 23, 2010 | Canon imageRUNNER C2620 Color Copier
How should i do photo copy of legal size
oh legal size you mean 8 1/2 x 14 in?
if that's what you mean, first we have to identify if your machine is set US standard. there you will be able to copy legal size. Otherwise if JP/EU standard, you can only copy 8 1/2 x 13 as the nearest size.
please check it first
if the sizes on the scree you see are A4, A5, A3, FLS, then your machine is set to JP/ EU standard. If you see LTR, INV, LGL, LDR, then your machine is set to US standard, and just select LGL for you to copy legal size.
that's it
May 20, 2010 | Panasonic DP-8016P Copier
INCORRECT PAPER SIZE TRAY: LTR
Hi mate ,
Prior to your issue that cassette size incorrect.
1)chk your device casette ,any size selector ?put it to the correct size.
2)It actually located at the cassette itself.
3)or u can chk at the add func key>custom setting>input correct size>register the size
Good luck mate ,pls feedback to me if there is any query ,i need to know u using wat model.Cos i can give u more detail solution.
PLs rate me !!!!!!Thanks
Oct 16, 2009 | Canon Office Equipment & Supplies
IR 5000-6000 LGL TO A4 PROBLEM
What country are you from ???? here in the US we do not use A4.
Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
Oct 11, 2008 | Office Equipment & Supplies
55 people viewed this question
jasbo
jasbo
