Question about Epson Stylus C43SX InkJet Printer
Maintenance tab not showing the level of ink
I have lost the Printer Driver and downloaded it from the Website. It worked fine.. But the maintenance tab in the Preferences window is not working properly. The nozzle check is working.. But the Amount of the ink is not displayed.. I am using a compatible cartridge.. Is that making problems? Thnx in advance..
  • 353 Answers
Have you properly installed the Status Monitor as well as the driver? If not, download SC4344_STM_3aE_MP.exe from:
http://tech.epson.com.au/downloads/product.asp
if this isn't the problem, report back.
Posted on Feb 10, 2009
How do I check ink levels on HP 7760 printer
Dear Jeannine,
Greeting!
Check estimated ink or toner levels for your printer to determine if you need to replace any cartridges.
NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, consider having a replacement ink cartridge available to avoid possible printing delays. You do not need to replace ink cartridges until you are prompted to.
Many HP printers display ink and toner cartridge levels on the control panel. Look for an ink drop or cartridge icon or an Ink Levels menu to check the status of each cartridge.
Figure : Examples of ink and toner level icons and menu selections on various HP printer control panels
If your printer does not have an ink level icon or menu, continue with these steps to check ink or toner levels from your computer or mobile device.HP Customer Support - Software and Driver Downloads, enter your printer model, and then clickDownload next to the full feature driver or HP Easy Start to download and install the driver.
Jun 06, 2018 | HP Office Equipment & Supplies
Hp photosmart touchscreen not working how can I check ink levels
If you have it connected to a computer then the HP utilities should be able to show the ink levels. You can also check the printer properties in the driver for a maintenance tab that should show ink levels as well.
Jul 25, 2015 | HP Photosmart D7260 Printer
Find out much ink left
If you have installed the full feature drivers for this printer, one can open the printer software and then select Printer actions>>click maintenance tasks and then select Printer toolbox and then select the Estimated ink level tab to view the ink levels for the printer. I hope that this helps. If not, here's a link to a downloadable user's manual with lots of info on your printer.
Apr 27, 2014 | Epson Office Equipment & Supplies
How can i tell the ink levels in the cartridges
You are either low on ink or the yellow cartridge is blocked. If you have a plug in the cartridge, doing a print head cleaning may help. On my inkjet printer, there are two levels of print head cleaning available.
Which brand/model printer do you have? Accessing the print cartridge level depends on the model and usually the software that you have installed. However, the software-provided level is an estimated level and may not accurately reflect the actual ink level in each cartridge. This is only available if you install the full-featured software from the manufacturer.
Generally, to see the estimated levels, if you have the full software installed, open the printer Toolbox. Then find a tab related to Maintenance and then get the estimated ink levels. For my HP printer, there is a specific tab just for the ink levels. (If you use Windows, there may be a icon for the printer in the notification area (on the right with the date/time information) that will let you open the software. Right click on the icon to access specific parts of the program.)
My printer has an option to print a quality test page in the Maintenance section which gives a better look at the ink levels. (For my HP inkjet, this is under the Device Services tab. Print head cleaning is also accessed here.)
Some printers with an LCD panel will let you access these maintenance items directly from the printer.
Please add a comment with your printer for additional information.
I hope this helps.
Dec 27, 2011 | Office Equipment & Supplies
V715w does not print color
I am one of the Dell Certified System Expert that work with Dell Printers before.
For this case first is try to check level of Ink.
-Click start or Windows logo.
-Go to All Programs or Programs, then select the printer program folder from the list.
-Select Printer or printer home.
-Choose your printer from the printer drop-down list.
-From the Maintenance tab, Check ink levels.
If the ink level is very low to none replace the ink
If the printer level is ok, try to run the test page to check if it will print colored, if it is the issue is only in the settings of the printer.
here is how to run test print
-From the Maintenance tab, click Clean Cartridges.
For more information about your printer here is the link:
http://support.dell.com/support/edocs/SYSTEMS/PRN_V715w/en/ug/en_ug.pdf
I hope this will help you a lot in resolving your issue.
Thank you for choosing Fixya
Feb 27, 2011 | Dell Office Equipment & Supplies
Misssing lines and no color
check your ink level, maybe it runs out of ink. try also cleaning the heads with the utility found on its maintenance tab
START>PRINTER AND FAXES right click on canon i850>printing preferences>maintenance
Jun 02, 2010 | Canon i850 InkJet Photo Printer
Checking ink levels on my printer
  1. Make sure that the product is turned on and connected to the computer.
  2. Click Start and click Control Panel .
  3. Double-click the Printer and Faxes folder.
  4. Right-click the icon for the product and click Preferences .
  5. Click the Services tab, and then click Service this Device .
  6. The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram.
Apr 04, 2010 | HP Office Equipment & Supplies
Hi,I've got a ip1800 printer that will not work ovbiously was working just fine until I try to replace the ink cartrige. Please help. Leo
try to reset your ink counter.. open control panel->click printer and faxes->right click your printer and click on properties (open printer properties)->click maintenance tab and click ink counter reset and check the ink box you alredy replaced and reset then.
2. if still not work check your print pattern in maintenance tab too and print..
3. cleaning your printer in maintenance properties and print check pattern again...
i hope this solve your problem.. good luck
Sep 15, 2009 | Office Equipment & Supplies
Refilled ink
Try checking under maintenance or ink settings, sometimes if the cartridges have been refilled they are not reset correctly and the ink level checking fails to work. There is sometimes and option to ignore these for refilled or compatible cartridges.
Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
--> Look for a "Maintenance" or "Tools" Tab across the top click one
--> Look for an option for "In" or "Ink Settings"
and click on one of these options to run
If you cannot find that then Try going into Control Panel
--> Right Clicking on your printer
--> Look for an option for "Cleaning" or "Deep Cleaning"
Jan 25, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Maintenance tab in preferences not working
http://www.fixya.com/support/r1468656-free_printer_drivers_lost_driver
Dec 01, 2008 | Epson Stylus C43SX InkJet Printer
Epson Stylus C43SX InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
