Question about Ericsson Lands Phones
My Ericsson 260 cordless phone is not working. The screen shows only the battery charge, and I cannot operate any of the keys.
Try giving the copper charging terminals on the phone itself a bit of a clean with something slightly abrasive that will clean/renew the surface. Suggest fine emery paper or something similar.
Posted on Dec 04, 2012
2 Suggested Answers
SOURCE: KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Posted on Oct 23, 2010
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Screen works when charging but then nothing!?!?
Yes the software is the problem. Try updating your firmware. It can be downloaded.
Jul 08, 2009 | Sony Ericsson w580i Cellular Phone
GE cordless phone showing low battery (model 27958GE2-A)
Your phone may have a faulty sensor. If the only notification is that your screen displays low battery, and there is no interruption or disruption of service or quality to the product you can most likely leave it as is. If your phone is still under factory warranty, do not replace the battery, ask for a replacement for a faulty product. I would personally test the lifetime of your phone by leaving it off the charger for a day, and if it lasts the entire day without dying, then it is a problem with your phone's sensor / battery indicator. If the phone dies after a few hours of use or standby, then there is a problem with your battery and your battery tester.
Jun 15, 2009 | Uniden Cordless Phone
White screen
i got the say problem 2 days back. I read some pots in forums. This is what worked for me. First fully charge the phone some. Get a friend's phone or something. Then get ready with the data cable and your computer with internet.
Goto Sony ericsson site.
search for w810i SEUS Sonys update system.
At the bottom result it says"Sony Ericsson - Support - Update Service Compatible with K510i W810i W200i .
Click on that and dowload the program. At the right corner it shows the phones which supports it.
install the program and run it.
do exactly what it says.
It worked for me. I got all my contacts and messages back.
Good luck
-Manoj
May 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Phone keeps freezing at sony ericsson screen
Try taking and leaving out the battery overnight. If that doesn't help, then try flashing your phone with the Sony Ericsson Update Service.
Dec 30, 2007 | Sony Ericsson W200i Cellular Phone
Blank screen
Solution for Frizzyloo:
The most likely problem is that the connections between the phone and the screen have disconnected or are not connected properly. See if the screen will work if the phone is slid down or half way up etc. Try pushing down on the area around the screen and see if it works then.
Also get it to a repair person if this problem is continual. The problem will not be covered under warranty unless you get it in for under a year and it's worth replacing the connections.
Solution for Zeewon:
Try starting up the phone with out the sim and if it starts fine then your sim needs replacing. Try the same with the memory card. Also check your battery, there should be a sticker around where the contacts are and if it's red then your battery and the back of your phone have been wet. Wipe the back of the inside of the phone then replace the battery.
Good Luck to you both.
Nat
Dec 25, 2007 | Sony Ericsson W550i Cellular Phone
Lands Phones Logo
150 people viewed this question
Top Ericsson Lands Phones Experts
Ali Reza
Level 1 Expert
Are you an Ericsson Lands Phone Expert? Answer questions, earn points and help others
