Question about Mercury P4VM800M7 Motherboard
Agp card problem
I m using ge force fx 5200 -8x agp card but the display is always from onboard , i hv seen all the bios feature
  • Chris Fell
    Chris Fell May 11, 2010
    Do you have the screen plugged in on the onboard graphics connector or the agp card ? if on the onboard, transfer to the agp card, go into cmos, look for the device settings for "primary graphics display" and set this to agp slot.
    Genius:
  • 1,605 Answers
Did you download the GeForce video driver for the card?
if not, do so now. if you did, did you install it?
Posted on Dec 01, 2008
I install a video card nvidia fx 5500 agp in the computer ,set in auto for the onboard video,and when i restar the computer .the video card is not working .and the onboard card as well.when i remove the...
Enter BIOS and disable your onboard video card, shutdown PC, add your FX 5500 , Turn on PC....simple and easy. I hope this solution will be helpfull for you!
Apr 06, 2010 | Dell OptiPlex GX270 PC Desktop
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't...
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Apr 16, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Agp card problem
Hi, usman update inf & bios of mother board.
Thanx
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
I have ge force fx5900u
Hi usafsohail.
It is possible the motherboard has a built in graphics card. When you add the FX card into the system you must disable the onboard graphices card in the bios not to load. Example; If the FX card is an AGP, you must enable the bios to boot the AGP slot first & not the onboard (Intergrated) video card. If you list the model number of the motherboard I can check if this is the case.
If you have you're manual for the motherboard you can check this you're self.
Mike
Jul 16, 2008 | Computers & Internet
Netvista AGP slot disabled
I added an FX 5200 256Mb AGP card to a 8307, and the Bios allowed me to enable the AGP port. And reports the device working properly.
May 26, 2008 | IBM NetVista PC Desktop
System doesn't see AGP card
Hello flaxx
I believe you'll need to find a way to disable your integrated (onboard) video in the BIOS. I know there isn't a direct way to do it but, please, see the next link. The user there found a way.
HERE is the way another user accomplished this task. (disabling onboard video). It concerns a different Asus motherboard but, I checked your motherboard manual, those same features are available.
HERE is the AsusTek forum for your motherboard. You can search and post here. There will be other users of that same board there that I'm sure will be able to help you.
HERE is your motherboard manual. However, I didn't see anything that particularly addressed disabling the onboard video.
Please, post back here w/ your results, questions, and any comments, etc.
Thank you
BJ @:)
Apr 12, 2008 | ASUS P4GE-MX Motherboard
New graphics card not recognised
Peter, you need to enter your bios & make a change.
How to enter bios? Start the PC & begin pressing the Delete key every two seconds untill the display screen opens to the bios menue. Peter here at the main menue of your bios look to
Pg. 29 in your motherboard manual. If you do not have your manual download it from the link provided:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=62&DetailName=Manual&MenuID=1&LanID=9
In order to move about in the Bios look at the bottom of the screen. There you will see how to move about using your keyboard.
Take your time in the bios. It can be confusing, even for me!
On pg. 30 change the Video (EGA / VGA) to AGP if available.
If AGP is not listed do not change.
Go to Pg. 35&36
Advanced Chipset Features
AGP & P2P Bridg Control Change to AGP if listed.
VGA Share Memory Size Change to 0 if possible.
The onboard/intergrated AGP uses part your system memory to function.
AGP & P2P Bridge Control
Play it safe & change to the size of memory to 256Mb.
Which matches your FX5200 memory
AGP Fast Write to Enable
AGP Driving Control set to Auto
AGP Master WS Write to Enable & same for Read.
Save & exit bios. The system will re-start.
If after your system starts back up & enters into windows & you notice you do not have video switch the cable connected to the other VGA out-put on the FX5200. Your display should show up.
Install your software for your new card.
Enjoy!
If you have troubles Pete just post back here & I'll address them.
& please vote...
Feb 24, 2008 | EliteGroup L7VMM2 Motherboard
CAN NOT INSTALL NEW VIDEO CARD?
sir are you using a onboard video before? or you got an onboard video available???
if the answer is yes just look at you bios settings about the video display and change it form PCI to AGP..
rank me if it helps
Jan 21, 2008 | Sony PCV-RS620G PC Desktop
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
