Question about Lexmark Office Equipment & Supplies
900.55 error on a c920
900.55 error on a lexmark c920 laser printer
  • 84 Answers
SOURCE: printer Lexmark T630
The error message is normally caused by either plugging accessories into the rip controller board or the engine board. In some models the board may be conbined. Or invalid or illegal commands sent from the printer. Try upgrading the firmware first. If that does not work you you may have a bad board. Hope this helps Click on the link below and select your operating system http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:359:0:0
Posted on Sep 10, 2007
SOURCE: 900 service error with lexmark printer
LEXMARK 900 ERROR GENERALLY REFERS TO A BAD CONTROLLER BOARD.
Posted on Dec 13, 2007
SOURCE: lexmark x215 all in one laser printer come lsu error
شكرا
Posted on May 27, 2008
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
How to reset Fuser Replacement 80 on C920 Lexmark - new fuser hasn't reset the warning
Go to Configuration by pressing the Check button the right arrow button while powering up the printer. Then choose reset fuser count. Hope this helps.
Jul 13, 2010 | Lexmark C920 Led Printer
Hi, I have a 200.00 paper jam in areas a and c. The paper jam has been removed but the error is still not going away. I have pulled out every thing that can be pull out and checked with no luck.
check any dis alignment on the paper jam sensors..or check any posible broken wire on its harness that leads to the paper jam section..
.....kenthbats
Jun 07, 2010 | Lexmark C920 Led Printer
I have a c920 lexmark with a fault code 920.000. my guess is that the fuserisnt heating up... based on the fact that its not getting hot... im guessing the fuser lamp has blown.... is there any other...
Hi, Majorly this Error 920.X display for a cold fuser. Some 920.xx error codes may be cleared by turning the printer on and off.
In general, fuser errors require replacement of the fuser. Fuser errors can be from a cold fuser or an overheated fuser. In your case you need to replace the Fuser.
Feb 22, 2010 | Lexmark C920 Led Printer
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
What is a 991.00 error
Assuming you are working on a Lexmark C920. The 991.00 service paper option relates to paper being jammed behind one of the paper drawers. Remove the paper drawers and check the connecters and also the housing for the tray its self.
Clear any errant paper and replace the drawers and all should be well.
Sep 23, 2009 | Lexmark C920 Led Printer
How to update s/n on Lexmark C920
go to lexmark site and download printer files
Aug 10, 2009 | Lexmark C920 Led Printer
Hi i have lexmark c920, every time i print parts of the print out are faded and its in the same areas of the page each time i print. I have tried another black toner and i am still having the same problem,...
it sounds like a paer problem or paper feed problem . first try new paper open a new **** & try that. if that does not work. your paper might be going in not flat.
Nov 11, 2008 | Lexmark Office Equipment & Supplies
920 Fuser Error
Jun 26, 2008 | Lexmark E342n Laser Printer
408 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
