Question about Toshiba CZ36V51 36" TV
Toshiba power led blinking
I have a toshiba model cz36v51 and the tv wont turn on all i get is a blinking power led. i think the problem might be an ic chip (str z4214) but im not sure as im only a shade tree electronics guy. any suggestions would be greatly appreciated. thanks mike.
  • Anonymous May 13, 2009
    Power light blinks when I turn the TV on - no picture, no sound. Cable company says it is a problem with the TV which I have had for only 8 years.
  • 81 Answers
Check your horonital output transistor could be defective.
Posted on Mar 23, 2007
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Toshiba tv power light flashing. Model. Number cz36v51 how can I fix it
What colour is the flash? Is there any picture and sound? Need to provide more data to diagnose the problem.
Feb 09, 2015 | Toshiba Televison & Video
Red led blinking. tv wont turn on model number
Hi Rick,
First of all, thank you for posting your question here at Fixya.
My first advice is to unplug the unit from the outlet at least 30 minutes to reset itself and check if the symptoms still persists. If yes, may I know if it encountered before then there's some instances that the unit will power up after a few minutes of pressing the power button key?
Also, please double check the model number of your unit, if I'm not mistaken, it is 50H81 not 50H87.
Jdvillanueva
Jan 21, 2012 | Toshiba Televison & Video
After power button is turned on the led light flashes, and the only way I can get a picture is to bang on the front of the tv by the power button.
Sounds like you have a "Dry Joint" or bad connection, or even a faulty power switch.. this is a fairly common one... try a switch replacement first? Or look for a bad joint on or around the switch connections.
Jan 30, 2010 | Toshiba CZ36V51 36" TV
The tv won't come on. The red light blinks instead of staying on.
Try unpluging the television for about fifteen minutes
Nov 20, 2009 | Toshiba CZ36V51 36" TV
Push power sounds like it turns on but it doesnt
Discharge the power from the set before you do anything. HIGH VOLTAGE!!! Look at the power supply. It will be in the area where your power chord is soldered in. Toshiba sets are notorious for the mosfet chips going bad. But your problem almost sounds like some bad capacitors. If the mosfets were bad, you wouldn't have any power to your buttons/LEDs. Replace all of the capacitors within the power supply section. They're cheap.
May 24, 2009 | Toshiba 42H81 42" Rear Projection...
I have a Toshiba cz36v51 that won't come on...
I do not have that make and model. However:
Some remotes have to have a code set that matches the brand of the tv. Your remote should have come with a list of brands and codes.
Alternatively, the instructions for your remote should tell you how to determine which code to use.
Mar 20, 2009 | Toshiba CZ36V51 36" TV
TV turns off by itself after being on for 60 seconds
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Jan 13, 2008 | Toshiba CN36X81 TV
Power light blinks
I would start with C869 a 2.2 Uf at 200 Vdc in the power supply. I have replaced a fair share of those in these sets. Of course the first thing to check would be the pico fuse in the power supply regulation circuits F860 a 4 Amp Pico Fuse and if it is blown, you will have to replace Q801 the Regulator IC Str-Z4214 Part # 23906369. If you're not that good at soldering and measuring capacitance and resistance, this would be a job for a more experienced tech.
Jan 24, 2007 | Toshiba CZ36V51 36" TV
Toshiba CZ36V51 36" TV Logo
293 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
