Question about Toshiba Satellite 1115-S103 Notebook
Screen Brightness gone too low on toshiba satellite 1110 laptop
Screen display has gone has suddenly gone too low. Not sure if I have hit some buttons to make screen suddenly dim. Cannot view screen at all so cannot get into control panel to adust brightness. Is their Function key and another key to press to get brightness back up on laptop screen.
  • Anonymous Mar 29, 2014
    Toshiba function keys somehow were turned off... not able to control volume, brightness, etc
  • 33 Answers
Hello Tim,
Sorry to answer u by this news :
this problem u have happening by 2 cases ..
1st Case :::: that's maybe ur screen lamps is broken ..so u can see the data but very dark or no Back-light .. so u will need to replace the screen..or advanced option but with expret person to change the lamps from another broken sceen,,
2nd Case ::::: The high-voltage board..it's small board built below the screen to give the screen the right voltage to light on .. so u will need to replace it also ..or Advanced option also but with expert electronic person to check it ..
best luck.
Posted on Dec 01, 2008
My screen only gets brighter when i plug up the computer into the wall socket
Posted on Jan 12, 2009
Turns out the switch on the Toshiba Satellite 1110 laptop that clicks in when laptop is closed was playing up. Laptop thought screen was down and closed when it was up and hence went into power management mode of lowering power to lowest level including dropping all screen brightness. Jiggled the switch and it then realised screen was up and returned screen brightness to correct level. Thanks to all who offered a solution.
Posted on Dec 02, 2008
  • ashleyka Apr 16, 2011
    how did u do it?
I have a toshiba satellite m305D-S4830 with OS Vista but the display is barely visible
If pressing the Fn and the F 3 or whichever F key for your brightness does not increase it then the invertor is possibly low emission. Replace the inverter.
Nov 09, 2013 | Toshiba Satellite Computers & Internet
What keys do i use to brighten or lower my screen brightenss on my toshiba satellite m55-s135?
deffinitely not a connection issue there should be some weird buttons by the f5 buttons look at instructions
May 06, 2012 | Toshiba Satellite M55-S135 Notebook
How to adjust screen brightness on Toshiba Satellite 1005-S157
You can adjust the the screen brightness by hold down the FN key and hitting F6 or F7. F6 will decrease the brightness and F7 will increase the brightness.
Jul 13, 2010 | Toshiba Satellite 1005-S157 Notebook
Laptop power is on, but will not load, and screen stays blank
I would take the laptop in to have it fixed. I believe it would be the cord connecting the monitor gone bad.
TRY HITTING "Fn" Button and the F** button that shows multiple displays. Check if the external display works
Apr 10, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop screen produces image, but there is no illumination
Hello
The screen brightness may be too low. That may happen in certain power regimes ( when used on battery power, presentation, etc.)
Here is how to change screen brightness on a Toshiba satellite that has the Toshiba Power saver software installed
Go to the Control panel, Click Toshiba Power Saver ( icon has two hands praying?) and increase the screen brightness. in each of the different regimes provided : Full power, High Power, Normal, DVD Playback and so on.
Hope it restores your computer screen to light.
Once finished, press the apply button
Aug 26, 2009 | Toshiba Satellite A105 Notebook
I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
Feb 26, 2009 | Toshiba Satellite P25-S507 Notebook
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Thankyou
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Low brightness to no brightness on the m55-s139 toshiba notebook ;what are the possibility fix?
The backlight has probably gone out in your screen. Replacing a LCD screen is fairly easy and can be done alot cheaper yourself rather than paying 3-400 bucks to hire someone to do it.
This ebay page contains the screen you need and instructions on removal and installation for your screen. It also contains the necessary information to make sure you are purchasing the correct screen.
http://cgi.ebay.com/TOSHIBA-SATELLITE-M55-S139-14-GLOSSY-LAPTOP-LCD-SCREEN_W0QQitemZ180238097667QQihZ008QQcategoryZ31569QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
May 11, 2008 | Computers & Internet
Toshiba Satellite 1115-S103 Notebook Logo
1,606 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
