Question about TallyGenicom (048959) for T2265, T2280, 7265, LA650, LA800 Print Server
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Posted on Dec 19, 2008
Our tally 2280 Dot matrix has an alarm code 025609413032 What causes this to be displayed on the 2280 screen.?
check out this FAQ page for the hardware alarm codes:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=295%3Ahardware-alarms&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 19, 2010 | TallyGenicom 2280 Matrix Printer
Pdf printing is not properly impression on the line priter tally t6090 ,plz help harish
Hi, maybe this TechNote will help you:
http://support.dascomeurope.com/index.php?option=com_content&view=article&id=296%3Apoor-print-quality-when-printing-adobe-acrobat-pdf-files-&catid=234%3Afaqs-t2265-t2280&Itemid=57&lang=en
Mar 12, 2010 | Tally Line Matrix T6090 Printer
Tally t2265 'check ribbon' hardware alarm... carriage moves ok, 2 new ribbons ...that came from other machines,,,, ribbon drive seems fine, could it be encoder strip??? please help!
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Jul 03, 2009 | TallyGenicom 2280 Matrix Printer
Model T2280. How can I correct AGA error?
This is normally caused by a bag AGA sensor.
TALLYGEN 447540 AGA ASSY T2265 New
Link lists a T2265, but the sensor is the same.
Jun 08, 2009 | Tally Office Equipment & Supplies
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
Aug 26, 2008 | Tally Matrix T2280 Printer
Please help
I am already faced this problem, This Problem is due to Bad Head cable. Repaced that cable, your Problem will be resolved
Aug 20, 2008 | Tally Dot Matrix T2265C Printer
Printhead hot error on tally t2265 but all pins fire ok, just stops and gives error, printhead is cool to touch, after a few minutes it prints a line or two again. it does this immediately, not after a...
The problem is with the main board when it gets print head hot immediately. The power supply is still functional, but something on the main pcb portion causes it to give an immediate "Print Head Hot" alarm
Jul 22, 2008 | Office Equipment & Supplies
Tally 2265 paper jam
I am not familiar with this particular printer, but dot matrix printers are not complicated. Being that it is old, it very well be that a sensor is dirty or bad. There probably is only one or two of them. I suggest you carefully take the cover off, and expose the platen roller. If it is removed easily, take it out and clean it with dish detergent and water. Better yet, use WD40, because it will revitalize the roller a bit. be sure to use the dish detergent to get the WD40 film off. Now, look for any small switches in the paper path. Something may even be holding it down. The switch part may only be an actuator, and you may have to follow the arm to the photo interrupt switch. Clean in between the posts of its an interrupt switch. If you can't find anything jumping out at you, its probably time for a new printer.
Feb 23, 2008 | Tally T2265 Dot Matrix Printer 917402
Computers & Internet Logo
295 people viewed this question
Top TallyGenicom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a TallyGenicom Computer and Internet Expert? Answer questions, earn points and help others
