Question about Canon CanoScan LiDE 25 Flatbed Scanner
Scanner does his plug into power or just the computer?
  • 103 Answers
Just the computer through the usd port
Posted on Dec 01, 2008
Hpscanjet 2400 is not powering on,what maybe the problem?
• Ensure that the power cable is securely connected between the
scanner and a live electrical outlet or surge protector.
• If the power cable is connected to a surge protector, ensure that
the surge protector is plugged into an outlet and turned on.
• Disconnect the power cable from the scanner and turn off the
computer. After 30 seconds, reconnect the power cable to the
scanner and then turn on the computer, in that order.
Jul 07, 2011 | HP ScanJet 2400 Flatbed Scanner
Same problem.Scanner does not connect to my PC with Windows XP
Did you plug the scanner's USB cable into the computer, BEFORE you installed the drivers?
This can lead to a driver conflict.
When a hardware device is connected to a computer, Windows automatically sets out to match up drivers for it. If no driver is found that ->directly matches the device, Windows matches up one of it's generic drivers. Kind of a "One size fits all", type of thing.
Then THE drivers are installed. Now Windows has a conflict of drivers.
Windows: "Do I use these, or THESE?"
Suggest you unplug the USB cable from the scanner to computer, (If plugged in) Turn the scanner off, and unplug it from power.
Then go to All Programs, (Start>Hover your mouse on All Programs), and look at the list to the right for the Agfa Snapscan software.
See if an "Uninstall" option is listed. If so click on it. (If it asks if you wish to save preferences - NO!)
If not, go to Add/Remove Programs, (Start>Control Panel>Add/Remove Programs), and find the Afga software in the list. Click on Remove.
DO NOT restart your computer, (Even if it asks)
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug your computer from power.
Press the Power ON button in, and Hold it in for a count of at least Five seconds. (Count, 1001,..1002,..1003,..1004,..1005)
Let go of the Power On button.
Do This ->Two more times.
What you are doing is clearing any CMOS Error Codes, (And resetting BIOS back to the factory default settings)
Plug your computer back into power. WAIT 1 minute, then turn it on.
After Windows has fully loaded, install the drivers from the CD disk you burned them to. If you didn't save the drivers to a CD disk, download the drivers again. Install them with the Installation Wizard.
After you're done, restart your computer.
After Windows has fully loaded again, plug the scanner back into power. If it sounds like it's resetting itself, wait until it's done. Now plug the USB cable into the computer from the scanner, turn the scanner on.
Aug 13, 2009 | Agfa SnapScan 1236s Flatbed Scanner
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
Hi my HP scan jet 3400c cannot turn on. what is a problem.
The scanner have two ports to connect to PC, USB and Parallel.
It has no Power switch.
Disconnect all cables from your scanner (USB/Parallel and power.
Plug power cable to the scanner, and then plug the power supply to an outlet.
Does it turn on ?
If not, than check the power adaptor.
If it turns on, then turn off your computer, plug the USB/Paralel connector to the scanner and to your PC and turn on your PC.
You should know that you can use only one connection for your scanner at a time, USB OR Parallel.
Parallel for under Windows98, and USB for Win98 and above.
Regards.
Apr 20, 2009 | Computers & Internet
I am trying to reinstall HP Scanjet 5400c but it keeps telling me it can't initialize, no scanner recognized...WindowsXP.. it worked before, why not now?
I had similar problem with my UMAX scanner on numerous occasions. I now have this pg earmarked for quick reference! may help I don't know for sure but it is an easy test and if it works your good to go!
It is important that you connect the scanner's power and USB cables in the following order:
1. Plug the power adapter cord into the scanner and into an outlet. The scanner's power will then be on.
2. Connect the USB cable to the USB port on the
back or front of the computer.
NOTE: If you unplug the scanner's power ,you must also disconnect the USB cable from the computer. To resume use of the scanner, remove the power card, the the USB cable.
Sounds like a lot but the order is essential!
If it works, High lite Do unplug USB/unplug cable back of scanner/and plug cable back of scanner then USB!
Good Luck Hope this helps!
Mar 26, 2009 | HP ScanJet 5300C Flatbed Scanner
HELP! My HP Scanjet5470C worked PERFECTLY - not anymore
u'r scanner have to turn on first for the computer regocnize
try another power outlet, if the scanner turned on, it means the power outlet u used now is poor...
u can check the power adapter first
Mar 12, 2009 | HP Scanjet 5470c Flatbed Scanner
Umax PowerLook 2100XL Flatbed Scanner won't power up
the light may have gone, change the buls, also have you got your installation cd you may need that just in case it is not found you have to reinstall
Jan 12, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Bought HP S20 New in box on Ebay......installed software......powered up and linked USB......message "communication with scanner lost" cannot rectify
I use an older USB Powered Hub between my computer and the S20 scanner, a Belkin I found at a garage sale for $2 works fine. It is only rated for USB 1.1. The S20 is a USB 1.1 device. My computer was "too fast" with its USB 2.0 ports and it looks like I needed to "slow it down". There is no way it will worked plugged directly into the computer, but plugged into the hub, and then the hub plugged into the computer, it is very reliable.
Windows XP had nothing to do with it, from what I can see. I had Windows XP on a previous computer with only USB 1.1, and ran into the problem when I got a computer with USB 2.0 ports.
Jan 03, 2009 | HP Photosmart s20 Film Scanner
Need help to hook up IBM color flatbed scanner
Attach one end of a parallel port cable to the parallel (printer) port on your computer and the other end of the cable to the computer port on the rear of the scanner. If you have a printer connected to your computer, you must disconnect the printer cable from the computer before connecting the scanner cable.
If you have trouble attaching a cable connector to a port, be sure that you are connecting the correct end of the cable to the correct port.
IF. . . you want to use a printer WITH your scanner, attach one end of the printer cable to the printer port on the rear of the scanner and attach the other end of the cable to the printer.
Plug in power cord and then power up PC.
Power on scanner. Install drivers. Restart PC to activate EZ Station buttons.
Oct 11, 2008 | IBM Color Scanner Flatbed Scanner
Linoscan manual
Setup is easy just plug in the cable in to the scanner and the other end of the cable plugs in to the back of the computer and make sure your computer is off. After you plugged them both in, plug in your power supply for your scanner then turn on your computer and it should do the rest.
Nov 01, 2007 | Heidelberg Linoscan 1400 Flatbed Scanner
Canon CanoScan LiDE 25 Flatbed Scanner Logo
21 people viewed this question
old marine
old marine
