Question about Panasonic Lumix DMC-LC70 Digital Camera
Memory Card Protected
My Memory Card is protected. I can`t turn it off. I have followed directions in maual but to no avail. I made sure batteries are fine. I`ve used camera and card since last year with no problems. Hope someone can help.
On the memory card itself there is grey slider. Make sure it is NOT in the lock position.
Posted on Jan 26, 2007
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How can I switch on memory card?
Make sure the memory card in not write protected. There is a small sliding switch on it.
On the camera, go to Settings and look for Save to Camera, Save to SD Card.
Jan 26, 2016 | Kodak EasyShare Cameras
I have a "! Protected Card" message on my screen
Look at the memory card again. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Fuji FinePix S2000hd Digital Camera
Write-Protection?
Put them into "my sounds" folder or into a music folder and use them from there. The ring tones are wright-protected.
Jun 22, 2010 | PNY 2GB microSD Memory Card
SD memory card not aknowledged,on start up goes to internal memory. when card is pushed up further says "this card is protected". does work after lots of manipulation of the card and constant turning on...
1. With the card out of the camera, go into the menu and find "format"...follow the on-screen directions. 2. Download any pics you want to save from the card using a card reader. 3. Be sure the slide switch on the side of the card is in the unlocked position. 4. Insert the card into the camera and follow the format procedure again.
Jan 21, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Protected card
Hi Jen,
It sounds like your memory card is locked. To unlock do the following:
  1. Remove the memory card from the camera.
  2. On one side of the card will be a switch.
  3. Change the switch to unlocked by pulling up or down.
  4. Replace the card in the camera.
The card should now be unlocked.
Now you will be able to take pictures (If the memory card was the problem)
Enjoy!!
KInd regards!!!
Jan 06, 2010 | Cameras
Protected card
hi take out the memory card, there will be a small button on the side push it the oppersite direction, this will 'unlock' it.
regards
Apr 07, 2009 | Vivitar ViviCam 5100 Digital Camera
I cant copy song in memory card its shows card is write protected
What sort of memory card is it?  can you remove it and install it in a card reader directly on your pc?  What is trhe phone?
Jan 14, 2009 | Motorola Mobility ROKR E6 Smartphone
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
Nov 19, 2008 | SanDisk 2GB microSD Memory Card
Memory card is write protected
you can see a tiny lock (kind of sliding button with the label ("lock") in memory card. Try it
-Saran
May 06, 2008 | Motorola Mobility ROKR E6 Smartphone
Panasonic Lumix DMC-LC70 Digital Camera Logo
71 people viewed this question
Top Panasonic Cameras Experts
Jay Plesset
cesarakg
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
