when i run the washing machine empty the drum rotates, when it is loaded it will try to rotate, but struggles, then stops and trys to rotate in the opposite direction and has the same problem.
I removed the motor and had a friend check it for me, and he said he was sure that the motor was ok.
Not emptying the water fully - need to be able to fix it myself and desperate to do some...
(More)
Not emptying the water fully - need to be able to fix it myself and desperate to do some washing!!!!!!! :)
Candy CNW156 is losing a lot of water and will not release door lock without mains power being...
(More)
Candy CNW156 is losing a lot of water and will not release door lock without mains power being turned off....is this simply overloading or something more sinister?! Door seals in good condition
candy cdb115 does a half wash then does not spin . stops then flashes start button and timer button...
(More)
candy cdb115 does a half wash then does not spin . stops then flashes start button and timer button at same time
Hi. I switched on my machine last night and it started on the cycle before it made kind of a popping...
(More)
Hi. I switched on my machine last night and it started on the cycle before it made kind of a popping noise and then I could smell burning/smoke. The machine won't work now but there is power to it and most of the lights are on the display so for delaying the wash the 3 hour and 6 hour are BOTH lit up etc. etc. Any ideas please? I did have my laptop plugged in at the same time and wondered whether it had caused the washer to blow a fuse? Many thanks :)
