Question about Mitsubishi Televison & Video
I have a Mitsubishi HS-M58V(B) VHS recorder with a tape stuck inside. I'm not fused about the tape but would like some advise on removing it as the kids still have many tapes they watch from time to time. I have removed the lid for a quick look but not done anything else. Thank you
  • swmanders Dec 02, 2008
    Thank you very much for your advice, I have removed the duff tape now and will test the machine with another tape when I get home.
    If it plays up again I'll bin it!
  • 166 Answers
Many of the older Mitsubishi machines suffered from the nylon tracks which are set into the metal becoming brittle and cracking with age there is not a lot that can be done with this problem and you may as well buy a new machine.another cause can be the mode switch becoming dirty and needs cleaning this is a rotary multi contact switch located under the mechanical deck.Hope this may be of help but the outcome is not good in any way.
Posted on Dec 02, 2008
Mitsubishi HS-U775 S-VHS machine has no sound. Playback, rewind, FF, Pause functions work.
Get a VHS head cleaning tape from Walmart and try cleaning the players pickup heads.
Oct 17, 2016 | Mitsubishi HS-U775 S-VHS VCR
Unit will record by peressing the record button. But when programmed to record, the unit kicks on per the program, tape runs but does not record anything
Vintage VHS recorders can get quite messy. Probaly you need to take it to service. Presume it's time to convert your family tapes to DVD.
Sep 25, 2015 | Mitsubishi HS-U445 VHS VCR
How to Remove a Stuck-Up Tape
Take the top of the VCR off and remove it manually. If you don't do this you risk ruining the tape.
May 03, 2011 | Mitsubishi HS-U760 S-VHS VCR
Can't get a picture on TV screen
I think the tape is blank. I mean not recorded.
Oct 24, 2017 | Mitsubishi HS-U545 VHS VCR
Plays for 3 secs, stops, and then ejects
This unit needs to have the "idler" changed as well as the belts. Over time, the internal rubber parts get hard ans slippery. There are safety checks inside that will stop the unit when problems are detected. With a slipppery idler assembly, the tape does not get wound into the cassette after passing the heads. Rather than have the tape collect inside and be destroyed, the unit stops. This is a relatively simple repair that any shop should be able to perform. Expect a parts cost in the $35 range. In my opinion, this unit is worth the repair as it will continue to provide service to you for years to come. New replacement units tend to last only a year or two.
Dec 30, 2008 | Mitsubishi HS-U770 S-VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
E2 error
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
Everything's in black & white
are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Aug 14, 2007 | Mitsubishi HS-U778 VHS VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Televison & Video Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
