Question about Maytag MAV7600 Top Load Washer
Washer I have a Maytag Atlantis Washer, model MAV7600. I just put laundry in and filled it with water and now it's just sitting there. I tried all cycles and it won't do anything.
  • ejej30 Nov 08, 2008
    The washing machine is full of water and it has just stopped. I read the previous solution and I am not able to do anything with the little screwdriver..help! Thanks!
    President:
  • 878 Answers
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. Catriver..post back.
Posted on Jan 27, 2007
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
Machine filled with water but no nothing.
if you can hear the motor running but no agitation then your motor coupling has broken,,it is between the motor and tranny!
Mar 13, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold water
ck for cold water coming in ..washer probably set to run cold only rinse on color cycle
Aug 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis washer
Dear Spencer,
OH the trouble I have seen with my washer. Its only 8 years old and I had the same problem with mine it would fill up the rinse cycle and then just sit there with the water in it. I had a tech come out and he told me I wasn't distributing the clothes correctly, mind you I'm 54 and I think I know how to do laundry!
However I had just 1 month ago replaced the water pump because my son decided he wanted to do a weeks wash in one load. So what I think happened is that somehow the machine was knocked out of being level. The guy said he lubricated the motor cradle and leveled the machine, knock on wood just for today the cycle is running all the way through. Hope this helps
utah55
Jun 24, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
Jan 11, 2008 | Maytag MAV7600 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
324 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
