Question about Refrigerators
My frdge compartment is freezing
Whirlpool side by side black problem is the fridge compartment is freezing food even though i have turned the temp up to 6 degrees it is still happening mostly seems to be when i put stuff in the middle shelves My whirlpool fridge has started freezing food .....what can I do?
  • annlizkelly Dec 03, 2008
    Thanks for all the suggestions....... I really appreciate your help ....... My hubby switched the fridge off for a few hours had a good look at it and
    apparently he found a little bit of plastic paper over that little hole
    at the back with the red thing sticking up! ....sorry I don't have a
    name for it but it is probably something to do with circulation ..... that seemed to cure the problem
    Thanks again ....I don't have to buy a new fridge!
  • Anonymous Dec 05, 2008
    GE profile Mod.# PSL23scma bs S/N ma412213 food section freezes product. Replaced the defrost controls. Unit still freezes. Box temp 32f. Temp setting on #1.
    Customer very upset
  • 89 Answers
Pehaps the damper door motor is burned out or the damper door is just stuck open causing to much air to flow into fridge side. Damper door is located at the very most top-back-left corner of the "fridge" side.... goodluck...
Posted on Dec 02, 2008
    Scholar:
  • 111 Answers
Could be that the little door that apportions some of the freezer air into the warmer part of the frig is broken. I'm guessing it has a simple wire lever to open and close it, and if it had been stuck in the past, somebody may have forced it, bending or breaking the wire.
  • 40 Answers
I really need more information. Like exact model number of said refrigerator. Here are some good tips. There may be a vent that leads to the freezer, if so close it. Second question is place a thermoeter on the top shelf in a glass of water for 4 hours, what is the temp. Do the same thing on the shelf that is freexing. If the tempatrues are equal turn up the tempature again. If not the circulation in the compartment is blocked. Make sure the the back of the carptmen has a gap to let air circulate vertically. Modern refriderators use air circulation to help reduce energy costs from compressors overworking.
Thanks PJ
How do you raise the temp for the fridge, food consistently freezes, button raises reading to 45, then drops back to 29 instantly.
A real problem, if your fridge continues to show 29f (-1.6c) then everything will obviously freeze, I know this sounds silly but you are trying to turn the temp up on the food compartment & not the freezer? Just a thought. If not please call the service centre @ http://www.dacor.com
Nov 20, 2013 | Dacor Epicure EF48NBSS Stainless Steel...
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Fridge freezing
I think you should call in a professional repairman to have a look at your fridge and fix the problem.
Jun 11, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Food freezing in fridge compartment in my side by side
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Jan 26, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fridge at room temp
Good day,
two common reasons fro this.
1. The fan motor in the freezer compartment has failed and is not driving air to the fresh food compartment.
2. The second common problem is the defrost system has failed, blocking air from entering the fresh food compartment.
First indication is frost building up on the rear panel in the freezer. Remove rear panel and inspect.
Here is an excellent tutorial on defrost system repair.
http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 04, 2009 | Whirlpool Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
May 14, 2009 | GE Monogram Refrigerator Built-In...
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This is not a 123 to diagnose. There may be a few reasons for this problem. You need service this time!
Here is a good service that I recommend to my customers,
in our 65 year old family run appliance business!
They answer 24/7
Not expensive!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
407 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
