Question about Epson Stylus C86 InkJet Printer
I am trying to install printer but cannot find disc, when I try to find the make on installation menu, this number of machine does not appear, which make is the nearest or compatable for installation
  • 903 Answers
Http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=41661
go here and select your version of windows and download the drivers.
I hope this helps
Posted on Dec 01, 2008
Hello.... are there any program to change language on my printer brother MFC-J220 Lcd from German to English . Because there is no language option in its program.
Try doing a factory default on the machine. Sometimes that will change the language. Make certain you have the right installation disc installed. As some are only for certain countries.
Aug 09, 2017 | Brother Office Equipment & Supplies
Windows failed to start
This usually happen sometimes because of the installation you do you can to try and resolve the problem:
1.insert the windows installation disc
2.make show you press the key which opens the boot menu on windows xp it's usually F9( it appears at the beginning when booting)
3.let the disc load and select install copy then repair or if you see repair select it.and continue from the.
Mar 26, 2012 | E-Machines eMachines Desktop PC
1300 printer will not accept my install disc
Please try this approach:
  1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark 1300 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
  2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
  3. Use the link below to download and re-install the corresponding printer driver for your operating system:
Simply follow the instructions on your computer screen to complete the installation.
Feb 04, 2012 | Lexmark Office Equipment & Supplies
I lost the installation disc to copy/fax/scanner machine and i cant find where im suppose to go online
What's the make and model number of the printer? Also what operating system are you using?
Dec 09, 2009 | Canon MX300 Office All-In-One Printer
UNABLE TO INSTALL LEXMARK 1275 ALL IN ONE IN VISTA HP
it does happen all the time when one is trying to install a printer yet the computer is not able to. i suggest you turn off your anti virus and windows firewall, remove the printer cable from the computer port or usb port. try to run setup again using your pinter's installation disc.
if the problem continues, then try this unadvisable option: plug your printer to the computer, turn it on. go to control panel and look up for add new hardware or devices. the wizard will search for a new hardware added on you pc. it will search on all drives, so make sure that you have inserted the disc. let the wizard continue copying files fron the disc. once the set up from the disc tries to run itself during the copying process by the wizard, eject the discand cancell all the proccess. go to start menu and look up for printers and faxes open there. if you see that the lemark printer appears on the printers recently added on your pc, then restart your pc.
try to print any word document. i am sure that if you followed my hacking tip correctly, the printer will work just like any other one.
please post me a comment about the outcome.
thanks,
wonder
Sep 22, 2009 | Computers & Internet
When trying to re-install from disc get error: 1607
The failure appears to be occurring because the installation script cannot obtain Scripting.FileSystemObject. This is most likely due to registrations belonging to your Windows ScrRun.dll being missing from your machine - and the problem may be specific to your machine configuration.
Click on the orb/start menu and type in the search box regsvr32.exe scrrun.dll
If the fix is successful
try running the install again.
Regards.
Aug 06, 2009 | Canon Cameras
Need to install Lexmark X4550 but only have MAC disc am on vista
Are you trying to install the Lexmark X4550 to your Mac computer? What is the exact OS of your Mac (i.e 10.3.x; 10.4.x or 10.5.x)?
You have to make sure that the pinter is compatible with the OS that you have.
I don't have a doubt with the printer since you mentioned that it worked with XP. To install the printer to your Mac, please follow the steps below:
If your printer does not appear in the Printer pop-up menu, find and install the appropriate driver. Check any CD-ROM discs included with the printer, or the website of your printer's manufacturer. Only users with an administrator account can install software.
Tip: You can also open the Printer List window from Printer Center (Mac OS X 10.2.8 or earlier) or the Printer Setup Utility (Mac OS X 10.3 Panther, or later).
Check the Printer menu again after installing the software. If the printer does not appear, you may need to do this:
  1. Make sure the printer is connected to your computer, plugged in, and turned on.
  2. For Mac OS X 10.2.8 or earlier, from the Printer menu in the print dialog choose Edit Printer List. The Printer List window appears.
  3. For Mac OS X 10.3 or later, choose Show Printer List from the View menu. The Printer List window appears.
  4. Click the Add Printer button.
  5. Choose USB from the first pop-up menu.
  6. Select your printer from the list.
  7. Click Add.
  8. Close the Printer List window.
If the printer will not work, you may download the driver from the Web and install it. Here, I have provided you the link where you can download the printer driver:
http://www.findmysoft.com/drivers/Lexmark-X4550-1-0-11-1-printer-driver.html
Just click the download button and install it.
Have a great day!
May 13, 2009 | Lexmark X4550 Multifunction Wireless Color...
Trying to install lexmark printer
Hi philpot
You can download the drivers from http://downloads.lexmark.com/perl/downloads/downloads.cgi
Make sure the printer software is uninstalled from Add/Remove programs and that the printer does not appear in Control Panel > Printers.
Disconnect the printer from the computer and run the installation file you downloaded from the lexmark site.
Does this help?
May 01, 2009 | Office Equipment & Supplies
No installation disc
You said you had a lexmark z600, what is the third digit of the model number. The 600 series exists but i need the specific model number to help you.
Oct 24, 2007 | Lexmark Z600 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
19 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
