Question about Grundig S350 AM/FM/SW Radio
I get nothing
I use my radio in Guatemala with a 12V adapter and it has worked great for years. Now, I get nothing. I have tried it with the 120 cord as well. When I push the power button, nothing happens. Is there a fuse anywhere?
I fixed it by exchanging the Glass Diode (D13) with another one.
(the old one was shorted to ground)
Posted on Aug 19, 2010
I replaced the protection diode, a 10v zener, with a 9v from my junk box. This did not fix the problem, but as least I have 6vdc going into the radio now. Looking further ... maybe an onboard regulator got fried. Still no source for a schematic.
Posted on May 13, 2007
I have one that I am repairing that has the same problem ... putting 12v on the 6v input shorts the protection diode to ground. I pulled the diode and found it to be shorted and currently sourcing a replacement. Since I don't have a schematic, I am guessing at the part number ... it is a 1N4xxx something, I think ... hard to read it. I'm pretty sure this is the only problem. If you are not an electronics tech, I don't recommend trying to replace the diode yourself. It requires a major disassembly of the radio.
Who repairs the belkin xm boom box
Are you sure its the Boombox thats bad. Have you tried it with batteries? I think there is a guy who repairs boomboxes on Ebay. You can get a replacement power adapter here:
https://www.tss-radio.com/products/xm-boombox-power-adapter-ac-1
May 20, 2012 | Belkin F5X007 XM Radio Receiver
I cant find power cord for my wd 1tb portable harrd drive what voltage ac plug can i use? D33015 N3565 E101559 THOSE ARE SOME NUMBERS ON HARD DRIVE
Dear Dodgeydude
you can buy the adapter directly from http://firstmybookexternalharddrivezone.blogspot.com/2011/02/pwr-ac-adapter-charger-switching-power.html
where as the specifications are Input : AC 120-240V Output : DC 12V 2A (1.5A Compatible)
please dont forget to rate
Gagan
Mar 15, 2011 | Office Equipment & Supplies
When I press the power button to turn the unit on,
Check your cord first, make sure it's in good shape. Sometimes the main transformer goes out, and you can use a DC adapter to bypass the 120 V source. Could be a fuse, or something else in the power supply inside the unit.
Mar 13, 2010 | Durabrand CD Boombox, Pink Boombox
I have a Gateway monitor that needs a power cord
http://cgi.ebay.com/NEW-12V-2-5A-Adapter-Power-Supply-for-LCD-monitor-Cord_W0QQitemZ220405347970QQcmdZViewItemQQptZBI_Electrical_Equipment_Tools?hash=item33512eb682
Or you can just type in 12v 2.5A LCD Adapter in an Ebay search. You can usually find a bunch of buy now power supplies that come with cords for a decent price. I've been using one of these for a year or so on my monitor.
Nov 14, 2009 | Computers & Internet
Use Sony ICF-C1IPMK2 in Europe
A transformer type (Linear Mode Power Supply) AC to DC power adapter with a 9.V nominal output, measures about 12.V without load when tested with a multimeter. A power adapter with a nominal output of 7.5 V, measures a little over 9.V. Considering a number of people across different forums reported the adapter's measured power output as 12.V, I think the nominal rating of the AC to DC adapter should be 9.V. However, keep away from Switch Mode Power Supplies.
Jul 21, 2009 | Sony ICF-C1IP White Powered Speaker System...
Sirius Sportster car kit - blown fuses
Try the other adapter and see if it works without blowing the fuse. If that fuse blows also, something is wrong with the radio.
Mar 25, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Cobra sr 900 scanner
Get a 12 volt cord from Radio Shack.
Jan 18, 2008 | Audio Players & Recorders
New Power Cord Stopped Working
DO NOT use the HP power adapter that is 19V / 3.95A. That is too much power for the Scanjet, which is expecting 12V DC (and a much lower amperage). It's possible that hooking up this power adapter may further damage the electronics inside the scanner. If the second adapter has stopped working then it is possible that the internal circuit board has damage already and another adapter may not work. If you have access to a multimeter / voltmeter you could check for the 12V coming from the adapter. If you're getting the 12V, then the internal circuit board to the Scanjet is probably defective.
Nov 17, 2007 | HP Scanjet 4470c Flatbed Scanner
Grundig S350 AM/FM/SW Radio Logo
295 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
George Etukudo
George Etukudo
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
