Hi we have set up the linksy router & it works fine the problem we are having is with the linksy adapter.We have installed it on our dell c600 laptop but when we restart the laptop it says something about code 10.And also there is no power lights on the card.We have uninstaled & reinstalled but still doesnt work
any help gratefully received!
Code 10 is a hardware code meaning something can't start due to wrong drivers or a defective device. Try the Linkksys item in another machine. If it boots the same way, the Linksys item is defective. If it works, then try updating your system. Is the OS (operating system) Vista? Check the CD that came with the item and make sure the driver is correct for that item. You may also want to try another brand like D-Link or Hawking. Both are very good.
It's a registry corruption in the networking section. It could possibly be fixed based on this info.
First with the card in, goto Device Manager and uninstall the driver.
Then goto Add and Remove programs in Control panel and uninstall the cards software.
Then shutdown the machine and remove the card and reboot.
Then click Start|Run
Type in RegEdit
Locate HKEY_LOCAL_MACHINE | SYSTEM | CurrentControlSet | Enum | PCI
OR
Highlight whichever you are going to change the permissions of (that is, highlight PCI or Enum).
Right click on it and select the Permissions option.
Now, you can change the permissions in a lot of differnet ways. I went ahead and added the Administrator Group and then gave that group Full Access. But you could also simply give the Everybody group Full Access. I think that you can change everything back after you get the driver installed, but I just left the Adminstrator Group with Full access on mine.
Ok, now reinstall your Network Card software, reboot your machine, Insert your network card and let it install the driver.
Then after you see that it is working you can go ahead and try changeing the permissions back in the same places in the registry (though, I didn't change it back so I'm not sure if it will cause the problem to occure again).
In any case, you will be surprised that it works for you, but odds are it will. .
Mic,
Couple of ideas for you to try, sorry if you've all ready given them a go
have you tryed installing the software first then plugging the usb adapter in?
Have you tryed a different USB port?
Regards
Nick
