No constant hot water from baxi 105e - Computers & Internet
Im guessing this is a boiler with on demand hot water or a on demand heater, if so a common problem is most on demands can only supply 3-4gpm so if you have a low flow shower head running it will keep up if you exceed the gpm output rating which can be found either in tech. specs. or on name plate. Keep in mind a tub faucet usually supplys 6gpm. Im talking in canadian gallons if I remember correct it is about 1 litre smaller than a US gallon.
Solutions; holding tank circuit, flow restrictor PRV on hotwater line. None of which are great options, buyer be ware of this common problem when buying on demand. Buy a hi efficient condensing hot water tank instead in my opion then you have capacity and can also use for hydronic heating.
Posted on May 07, 2009
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 03, 2013 | Hardware & Accessories
Hot water not working on my baxi combi 105e
sounds like its the diverting valve
Dec 08, 2010 | Plumbing
Woke up the other morning with no heating or hot water from my 5 or 6 year old baxi 105e combi.i have,within the last 2 months, replaced the central heating temp sensor,and currently have the usual(and...
Per the User's Operating Instructions you want to check the condensate drain. Make sure it is free and clear. Also check the ingnitor, ensure there is no debris or buildup that could prevent it from firing properly.
Also, here are the Installation and Service Instructions that might be of help to you.
Without being onsite with toolbox in hand, I hope this information is very helpful to you. :-)
Mar 31, 2010 | Heating & Cooling
Baxi 130HE losing pressure
I would go with the valve first cheaper, then see if it still doing the same thing
Mar 04, 2010 | Heating & Cooling
I have a baxi 130he which loses pressure and I have to top up once a day. The copper pipe outside which I believe is an overflow is constantly dripping. Boiler runs fine central heating and hot water.
Hi the pipe out side is the pressure relief valve change the valve or it has something stuck on the seating , changing it will stop the pressure drop
Mar 03, 2010 | Heating & Cooling
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
My daughter has a Baxi Combo 105e fitted with an optional timer. I believe that the timer is possibly a Grasslin although it has no name on it. Although the clock goes round, the Central Heating doesn't...
I have a Baxi Combi 105 HE boiler that has just been fitted and it has the optional 7 day digital timer but no instructions on how to set it does anyone know where I could get them from. Many thanks
Feb 21, 2009 | Hardware & Accessories
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Computers & Internet Logo
333 people viewed this question
Alun Cox
David Payne
David Payne
