Even though there is no sound the system is stuck on radio and wont let you change to tv
    Sergeant:
    Champion:
  • 346 Answers
Press the sap button on remote
Posted on Dec 02, 2008
Channels wont unlock it is locked on 18 even though it is only a 14 channel radio
It might be possible your number 18 is the interference eliminator code. Your radio may be stuck in programming mode which would be caused by one of the buttons being stuck or the tactile switch behind it on the component board being faulty.
Best regards.
Mar 23, 2014 | Motorola Talkabout T5100 (14 Channels)...
I'm tring to change my sylvania tv 6424tfs to channel 73 it's not letting me
It sounds like the main system control memory IC to your set is faulty. Even though, this IC is very small in size, and very cheap to buy, the function to it, when the TV is switched on is great. It will be best to contact any service technician in this case. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 10, 2013 | Sylvania 6424TFS 24" TV
Wont stop changing channels
Check and replace the main system memory IC. It is faulty. It is a very small IC, won't cost more. An eight solder terminal IC. Even though the physical size is small, function to it when the TV works is great. The work is a skilled one.
Jul 29, 2012 | Emerson LC320EMXF 32 in. LCD TV
RCA F19281 Stuck on Channel
Do a hard reset to this first. If it do not help you, make sure that the main system memory IC of your TV is faulty. This is an 8 solder terminal IC, vary small in physical size. Even though it is very small, function to it, when TV works on is great. This is an easy to get IC, not cost more. But, replacing it is a skilled work indeed. You must have sound knowledge in electronics, and all desoldering and soldering equipments.
To make a hard reset to this set, unplug the TV from AC mains, and re-plug it in after 10 minutes or so. If the problem is with 'system Reset' this must solve the problem.
Jun 22, 2012 | RCA F19281 19" TV
5738z dvd driver
sounds to me like the dvd drive might need to be cleaned or replaced
Nov 18, 2009 | Televison & Video
My surroung sound wont play sound
Have you checked your connections?
Some surround soound systems have a source button (used to select the device you would like to play.
i hope this solution is helpful.
Feb 12, 2009 | LG Televison & Video
Radio Station stuck on one station and wont change!
sounds like the radio is locked up.... if the radio requires a code do you have it and know how to install it... if so ... unhook the battery for about 15 minutes and hook it back up... should work ok then...
Robert
Please take a moment to rate this solution thanks
Jan 23, 2009 | 2004 Chrysler PT Cruiser
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
Surround Not Working on TV
well for one thing .. on cable it has to be in surround sound.5.1 or 6.1 for it to true surround.your dvd and cd will be fine .. if you just want to have sound coming out of all speakers you have to adjust your sound settings but it will not be surround sound though
Nov 24, 2006 | Sony DAV-DX250 System
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
