Question about GE XL1800 1100 Watts Microwave Oven
Microwave won't work. The time is frozen, buttons dont work.
I have a Sharp R-395 microwave. In the last month it has stopped working 3 times. The time is frozen on when I tried to use it. The buttons dont work and the light inside doesnt come on. The only way to get it to work is to turn the power off. (It is in a wall unit and the power cord is behind the oven.)
Any suggestions would be greatly appreciated! :)
  • rbu76911 Dec 02, 2008
    no definately no spray cleaner involved. It was only purchased on 1/7/08 so the buttons shouldn't be worn out yet!
    I email sharp and they say it's a power surge from other appliances like fridges etc that is shorting it out and it is not a problem with the microwave. It is only plugged in with the oven so I am still not sure what to believe???
  • William Miller
    William Miller May 11, 2010
    Is it possible that some spray cleaner accidentally got into the controls?
    Direct spraying of cleaners on the keypad and steam from the
    cooktop can damage the controls.
    Always spray non-ammonia cleaner on a
    soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
    Always use
    the vent fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
    If it does not dry out over time, it may need to be manually dried or blown out.
    The keypad may be damaged or worn out, or control unit may be damaged.
  • GE Master
  • 9,086 Answers
I have over 20 years experience with microwaves and over 25 with all other electronics, and I'll have to say it sounds to me also like some kind of power surge "scrambling" its "brains".
Or possibly its power is being interrupted for a fraction of a second and having the same effect.
A microwave should really be on its own circuit breaker.
Microwave ovens, refrigerators, toasters, and electric ovens are very high current devices.
There are power line (mains) surges created when they cycle on and off.
If the microwave can't be on its own breaker, then maybe you can try a power strip with a surge suppressor, or better yet, a power strip with a surge suppressor and a built-in noise filter.
Or it may be that there is a subtle bad connection on the circuit board or at the fuse holder.
These kinds of problems are difficult to diagnose, and even harder to do remotely. Especially since I'm in the US! *grin*
I would strongly suggest that if you can't cure this with a surge strip or similar, please carefully document when and how it fails, then while it is in a failed state, open the door (to keep it from starting on its own) and call Sharp customer service at 1300 13 50 22.
Or you could visit here and click on Service Centre Location search.
You should have a one year warranty, so you should get in touch with a Sharp-authorized repair center.
An over the range type will include home visits in the warranty, but not if it's a counter top model.
You'd have to take that type to the shop yourself, and of course that would mean unplugging it, which would reset it, and the repairman may never see if fail.
If you wait too long, your warranty will be expired, so I'd get in touch with the shop.
Good luck.
Posted on Dec 02, 2008
How do I defrost a package of frozen hamburger meat (2.25 lbs)on the Sharp Carousel R405JFK microwave ? The instructions on the front of the microwave are sort of confusing...
try defrost = 2.3 enter/start I use my sharp (not a R405) all the time to defrost meat and that's how mine works , I know its a bit confusing as defrost goes by weight not time like the cook mode does
Sep 29, 2016 | Sharp Microwave Ovens
Door of sharp microwave will not open
Take it back, if this becomes a problem then you will have a harder time getting customer satisfaction.
Jul 09, 2012 | Sharp R-930AK Convection/Microwave Oven
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
My microwave stop working the clock and timer works but food is still cold. (The round cardboard piece on it's ceiling fell off about 3 months ago.)
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Sharp R-1480 Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
R-209BK Sharp Microwave buttons inoperable
I had this problem too:
it turns out that it (apparently) just needed some 'warm-up' time!
After being plugged in for about 15 to 30 minutes,
the buttons suddenly "came to life"...
Note that when it's flashing 88:88 you are supposed to _start_ with the 'Stop/Clear' button. After that, set the clock (press "Clock", enter the time with the number pad, then press Clock again).
Hope that helps.
Sep 01, 2009 | Sharp R-1502 Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Microwave won't work; timer word stuck on screen
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Our site is linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JVM1340AW/BW/WW Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
559 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
