Question about Garmin nuvi 205 GPS Receiver
GPS would not turn on
I just bought a new GARMIN NUVI 205 and it keeps telling me there is no maps avaoilable and i cannot even change the screen or try and do any settings on the screen. I then pressed the "reset" button at the bottom of the GPS. Now it would not even switch on.......the battery is partially charged, but charger is not plugged into the car at the moment.
I understand the maps should be pre-loaded with this unit.
Please help
Download the manual and find the reset button..it should start right up.
Posted on Jan 17, 2011
  • 3 Answers
Have you already tried the webupdater or registred the device on garmin.com? There you should get an free mapupdate which could replace your broken maps.
Posted on Dec 04, 2008
Change country
Do you have the map checked (enabled) on the map screen? At the main menu, press the tools icon, then the map icon and then the map info button. You should see the Europe map listed. Make sure it is checked. If it isn't, then the map will be turned off. Once it is enabled you should be able to perform searches for places in Europe
May 15, 2013 | Garmin Nuvi 205 W 205w
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Need serial number for garmin nuvi 205 so i can get map updates
Doesn't matter what the serial number is, you have to pay for updates unless you bought the lifetime map update package. Try going to Garmin.com
Jan 26, 2011 | Garmin nuvi 205 GPS Receiver
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 205 keeps saying it is connected to the computer when it is plugged into my car charger. It worked great until the original charger broke and I had to buy a new one. Now this charger...
When your Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Mar 06, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205 series, keeps beeping and "loading maps" I tried shutting it off and then holding the reset and turn it back on. it will not turn back on this way. if i push reset w/it on, it shuts off.
You can restore the Nuvi 205 system software to its factory condition by running Garmin's WebUpdater service. You may also want to try a hard reset of your Nuvi.
These are both good steps to take when a Nuvi starts acting up.
I hope that helps.
Dec 21, 2009 | Garmin nuvi 205 GPS Receiver
Garmin NUVI 205 when turned on says can't unlock maps!?!
Whenever Garmin Nuvis have map problems, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Oct 24, 2009 | Garmin nuvi 205 GPS Receiver
I am trying to register my nuvi 205 on garmin website but it keep saying that this serial number already registered. by the way its brand new, I just bought it yesterday
I HAVE SAME PROBLEM SITE SAYS TO CLICK ON FIND DEVICE WHEN I DO IT IT JUST BLINKS AND SAYS IT AGAIN WHEN I GO TO ANOTHER AREA IT SAYS NO DEVICE FOUND REGISTER DEVICE?????? I AM READY TO THROW THE DAM THING IN THE TRASH AND USE A REGULAR MAP
Jul 09, 2009 | Garmin nuvi 205 GPS Receiver
Gmapprom.img file in Garmin Nuvi 205 corrupted
Connect the Nuvi to a PC with the USB cable, then hold the power button to ON position. It happend to me before and it worked.
Good luck
Mar 25, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
455 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
