Question about RCA BD20TF10 20 in. TV/DVD Combo
Screen is green
Hi , I got my t.v and it is green .I got a remote and tryed to adjust the color but I can't see what I am doing because it is blury. What do I do keep trying to adjust or email me back thanks!
    Scholar:
  • 119 Answers
Ru51, or ru551 is bad. i suspect more ru51. it is 22k ohm 1 watt resistor. remove the part & test it with a multimeter. & replace that bad part. good luck.
Posted on Jan 26, 2007
Green screen
1.) Press and hold down the "Menu" key until the manufacturer's logo appears on the screen. This could take up to a minute or more. Release the "Menu" key when the logo appears.
2.) Immediately press the "9," "8," "7" and "6" keys in this order. Press the "Enter" button on the remote to enter the "Service Menu" screen.
3.) Press the "Menu" button to go to the second of the two "Service Menu" screens. Press down on the "Down" arrow until you highlight "Color Calibration." Press the "Enter" button to enter the "Color Calibration" screen.
4.) Select one of the color bars on the screen. Adjust the color by changing the values of the color bar by pressing left and right on the "left" and "right" arrows on the remote. Repeat this procedure with the other color bars as well. Stop adjusting the colors when the green cast is no longer present.
5.) Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made.
Now turn the T.V. off. When you turn it back on it should reflect your personal preference.
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM4Pfcki
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3rDVkt
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3hkBLp
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3VlPaY
Read more: http://www.ehow.com/how_7302235_fix-tv-screen-green.html#ixzz2fM3H5rYm
Sep 19, 2013 | Samsung Televison & Video
My ws65513 has way to much green color in it.How do I adjust the color?
First thing to do is turn color all the way off and examine screen--is it black and white or another color?
If you cannot tell peek in the back with set on at the 3 lens which are red, green and blue--are all lit or not?
Jun 16, 2012 | Televison & Video
I have a problem in my BPL TV(FHR-21) it showing a green color
How to Fix a TV When the Screen Is Green
A TV is calibrated by the factory to provide a "standard" picture that attempts to appeal to the vast number of buyers who take the set home. To adjust a TV picture that is too green, you must first enter the hidden "service menu" that technicians use. Adjusting the colors to remove the green cast will save you the cost that would otherwise be incurred from a TV technician coming to your home. No special tools are needed, nor any expertise in how the TV works.
Press the power button on the remote of a TV whose picture is too green in order to turn it on.
Press and hold the "Power" button on the remote to exit the "Service Menu" and save the adjustments you have made. Turn the TV off.
Sep 14, 2011 | Audio Players & Recorders
Our tv is blury, double vision with whites going
There seems to be two problems with the unit. The first symptom indiates your convergence IC's needs to be replaced. The second symptom coud be a several things, 1. Bad connections on the Crt board of the green tube, 2. The 200v screen bias voltage supplied by the flyback could have bad connections on it. Seems you have intermittent cold solder joints. Check the D board around the Flyback area for bad connections, or old grey looking solder connections all should look shiny. 3. The Green Crt maybe going faulty, the lines going thru the picture are scan lines and indicates that the Screen controls are to high. But i know you have'nt adjusted these so i would suspect the Green Crt is Faulty. But check solutions 1&2 first, One way to find out if its bad is to unplug the green crt board from the tube and turn the set on if it stays on and does'nt shut down then it is faulty, also while turning on look at the crt's neck for sparks which indicates arching in the tupe and will need to be replaced. Replacing the Convergence IC's will solve the distorted pic issue.
Nov 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Yellow arch on bottom left of screen. I have
OK, HERE are the instructions:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Toshiba entry to adjust
With the set on press MUTE on the remote.
Then press and HOLD mute for several seconds and while still holding it on the remote press Menu on the front of the set.
A (S) should appear in the upper right corner of the screen. (It means you are in the Service mode)
Press menu again on the front of the set
7 on the remote will call up the convergence grid
3 on the remote will change the color to adjust from red to green to blue(do not adjust GREEN)
You navigate the grid with 2, 4, 6, and 8 buttons.
To stop the cursor from blinking so you can adjust at any point use the 5 button—to move again use the 5 button.
When you finish you exit by hitting 7 on the remote again.
Sometimes you have to try a few times to get into the menu—I have had my problems but once in it is easy.
if adjusting does not cure the problem one of the convergence chips this set uses and or a resistor are bad.
Let me know what happens and if you need more help let me know
SD TECH
Sep 30, 2009 | Toshiba TP50H50 50" Rear Projection...
The pitcher is blury and need to be ajusted , how do i do that
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blury ,double vision, and cant brighten up
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 29, 2009 | Televison & Video
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Green picture
I'm not sure about this model but most projection tv's have a focus/screen control block usually located behind the front grille where the speakers are. The grille usually comes off easily. If there are no circuit problems you can adjust the red green and blue picture tubes there. Also the focus. It will be written somewhere screen and focus: Three for screen and three for focus. If you find the screens then adjust them slowly clockwise for increase brightness on the red and blue and you may have to reduce the green. Adjust for best picture. If the picture does not adjust too good then the tubes are weak. Only if there are no circuit problems Hope this helps
Dec 30, 2007 | Mitsubishi WT-42313 42" Rear Projection...
RCA BD20TF10 20 in. TV/DVD Combo Logo
49 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
