SOURCE: SHARP AL-841 Paper Misfeed Error?
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
SOURCE: SHARP AR5316 SHOWING PAPER WHILE NO PAPER JAM
try to chek if the actuator of the exit sensor is ok you will find it when you open the side door exactly attached to the heater try to check the end is it in plase or not if not use sim 30 sub1 to check all sensors you wil solve your problem
SOURCE: The "Paper Jam" light on my Sharp AL-1631 copier stays on
The paper detector on the fixing units have a history of going bad. The fixing unit is the hot roller above the drum inside the right door on the top. As the copy comes thru the rollers the paper hits a plastic lever that is spring loaded and located in the middle of the fixing unit. The sensor is all the way to the right side of the fixing assembly. If you move the lever in the middle you'll see a piece of plastic moving on the right, that piece comes out of the sensor and if can't reset the jam, that piece may not be resetting itself back inside the sensor. This is difficult to try to explain.
Good luck
Bob
SOURCE: Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
SOURCE: Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
