Question about LG Refrigerators
LG Fridge gets very hot on panel ( by the door)
My LG fridge ( electro cool) is almost 3 years old now. It recently started getting very hot on the side panel where you open the door. Sometimes it gets so hot that when you accidently touch it, it burns your skin.
Is this normal, could it be that the fridge is taking strain keeping the food cool during summer. What I can do?
  • lorraine_der Dec 07, 2008
    Thanks Larryyb - it worked! Fridge is cooler now - Lorraine
    Sergeant:
    Champion:
  • 291 Answers
Pull frig out from wall and take back off lower part and check the cond motor to make sure it is blowing and chances are it isn't so it will need to be replace / if so you can set a small fan behind to blow on compressor and coils to keep it cool till you can replace it / larry
Posted on Dec 01, 2008
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
LG fridge LFX25991st Ice dispenser panel keeps getting stuck
Of course it's under warranty. Call back & kick up a storm. Every singe item on that fridge is under total warranty.
Nov 20, 2013 | Refrigerators
I have a LG fridge double door top freezer model no GL-T262QM. the refrigeration compartment is not cooling.
ihave a lg.double door refri model T262QM about 7 years old. no cooing in freezer so i want to get cooling coil capaliry data i am technician
Mar 21, 2011 | LG LRTN22314 Top Freezer Refrigerator
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
I have a 15 year old Jenn Air Fridge/freezer Model no JRSD249OT . Recently side of doors feel hot and now fridge not getting cold. Appreciate any advice
You will need to pull the fridge out and remove the rear lower panel. If the unit is operating you will be looking to see that the fan in the rear is also operating. Most likely it is not. You will need to replace that fan motor if it is not.
May 21, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
LG Bottom freezer refrigerator Model LFC21760 does not cool
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages
Sep 28, 2009 | Refrigerators
My LG freezer is cooling while the refrigerator doesnt.
OK THEN FROM WHAT YOU SAY SINCE THE FREZER WORKS BUT NO FRIDGE IT SOUNDS LIKE A DOOR SEAL FOR THE FRIDGE DOOR GONE BAD,DIRTY,WARPED,OR WORN OR THE DOOR IS'NT SHUTTING ALL THE WAY THIS IS THE NEXT STEP OF WHAT TO LOOK AT
Apr 12, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
Lg electro cool fridge
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
Apr 08, 2008 | LG Refrigerators
Refrigerators Logo
190 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
