Question about Radio Communications
I can not hear people talking to me on my cb but they can hear me
I can not hear people talking to me on my cb but thay can hear me.
The speaker and volume control are fine and my unit is sending out a good clear signal.
The unit is a GME TX3200.
  • Leonard_Loh May 23, 2009
    My Motorola T6220 transmits just fine but I cannot hear incoming transmissions even with the volume cranked up all the way. Even the beeps when buttons are pressed sound soft and scratchy. The speaker's diaphragm looked okay when I took the radio apart. I suspect the voice coil in the speaker has had it. Is there any way to replace the speaker?
Nothings for free is it
Posted on Dec 02, 2008
Cobra 29 lx
without a speaker hooked up to youe PA it wont work.Actually it should be a bullhorn type speaker that can both transmit and receive.this way you should be able to hear yourself talk.
Aug 22, 2014 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
because when you switch to PA it is because you are on the outside of your vehicle.When another party calls you ,you can hear them and then go to your vehicle flip it to cb and talk to your party.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
Does the connex 3300hp have talk back
Any radio can have Talk Back.. all it is is leaving the RX active on TX and the sampled audio goes to the speaker that you can hear....
Feb 17, 2014 | Connex 3300 240-Channels Base CB Radio
Hi we just bought a new cb galaxy people can hear us we cant hear anything no squelch no talking
Plug an external speaker in the back of radio & see if you can hear anything. Also,you may want to take bottom speaker panel off & make sure the 2 wires coming off speaker are plugged in to the back rightside of radio. These things I would check first.
Mar 15, 2011 | Radio Communications
I hooked up my CB when I talk on it it I hear myself over my radio speakers.
do you have a talk back modification you don't know about or there was one and someone didn't remove it right or the speaker was wired wrong check your radio ground .or try a diffrent mic.
Jan 09, 2011 | Uniden Radio Communications
CAN CALL OUT BUT CANT HEAR BACK.
it sounds like you have something wrong inside cause if you can call out you sould here back take it in and get it fixed you can take it to any truckstop and thay will have a CB shop inside if not thay can tell you where to go close by
Dec 30, 2010 | Icom ICF221S CB Radio
My cb has to be has to have to be on pa with external speaker pluged in on pa side to hear people talk. to talk it has to be switched to cb
Take the cover off, and get a can of contact cleaner,make sure its turned off,and spray the PA switch from the inside of radio,spraying into the switch, flipping it up and down as you spray several times,may need to replace the switch. hope this helps..
Mar 26, 2010 | Cobra 29 LTD CB Radio
I can't hear through my internal or external cb speaker
Can you hear static when the squelch is at minimum ?. If you can hear static then tere is nothing wrong with the audio system. If you are sure about the squelch, connect goosd speaker directly to the 2 wires coming from the main board bypassing the speker jack. if there is still no sound then the audio amp chip is defective. The audio amp can only be damaged if the output is shorted for a long period of time.
Mar 02, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
176 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
